VW Gear Box Codes & Gear Ratio's
Moderator: Henryhoehandle
Post by david58 » Tue Oct 09, 2007 1:26 pm
Type 2 gearbox codes
Codes below are for T1 Beetle unless otherwise stated.
General Information - Beetle Gearbox Part Numbers Should start 113 For a Manual Box and 001 for an Auto Box.
The Gearbox Code. Is followed by 5 numbers the first two are the Day the second two are the Month and the fifth is the year. AT22104 was built on 22nd October 1974.
Bruce2 wrote: To date a gearbox with only numbers and no letters in the code, go here:
http://www.thesamba.com/vw/archives/inf ... dating.php
caslor
Post by caslor » Tue Oct 09, 2007 3:12 pm
nice!!
i think that post must became a sticky...
Post by david58 » Wed Oct 10, 2007 8:13 am
Post by david58 » Fri Oct 19, 2007 7:11 pm
Henryhoehandle
Post by Henryhoehandle » Sat Oct 20, 2007 7:25 pm
Hopefully these are accurate. I know at least some of them are. If anyone has any to add, let me know and I will add to the list.
shopteacher
Post by shopteacher » Thu Nov 01, 2007 10:53 am
so a trans with
46
113 301.103
D
is a type 1 Car IRS... any other info from that number?
turboblue
Post by turboblue » Thu Nov 01, 2007 11:21 am
shopteacher wrote:so a trans with
46
113 301.103
D
Post up the code as seen in this thread's picture Teach.......
That 113xxxxxx is just a VW part number, probably for the case.
http://www.shoptalkforums.com/viewtopic.php?t=99606
Gary
Turbo VW Sand Drag Buggy
2013 Polaris Ranger 4x4
My Website
Shop Facebook Page
VGM
Post by VGM » Thu Nov 01, 2007 10:45 pm
Thank you for that info.
Flagbuggy
Post by Flagbuggy » Tue Nov 06, 2007 3:47 pm
Hi there Guys
I got a reduction box tranny without any Digits the no`s are
4951660
What info is available on that one
2.4 Type 4 Turbo Flag buggy 11.1 sec
13BT 240KW Cabriolet Bug
66 Freurwagon Long term project
66 Squareback Sunroof Project
2000 NB VR6 Turbo Project
84 DC 1.9WBX
86 Kombi 2.1 WBX
bedjo78
Post by bedjo78 » Mon Apr 28, 2008 7:25 am
I got AV code on SSC type1 , please what is the ratio of the gear
Bruce2
Post by Bruce2 » Tue Apr 29, 2008 2:17 am
bedjo78 wrote:I got AV code on SSC type1 , please what is the ratio of the gear
That is a Type 181 open diff gearbox.
4.12 R&P
3.78
2.06
1.26
.93
dooker
Post by dooker » Wed Aug 13, 2008 10:20 am
any place i can find Type 2 gearbox final drive ratios? thanks.
turboblue
Post by turboblue » Wed Aug 13, 2008 10:23 am
dooker wrote:any place i can find Type 2 gearbox final drive ratios? thanks.
http://sandlizrd.baja.com/gears.htm
Gary
My Website
Shop Facebook Page
Post by david58 » Fri Nov 28, 2008 7:26 am
Marc wrote:Blown Gluben obviously knows where to look since he provided the trans serial number already. There's no letter code stamped into older transmissions, but #8074135 would've been a 1965 model. Better than say, a 1962, but not a very strong box. I'd put the effort into finding a good `67/`68 trans and swapping the axles.
If staying 6V there's an adapter sleeve that'll allow you to run a 6V starter in a 12V trans but I don't recommend them. Better to have the starter pinion shaft turned down to the "12V" diameter.
Anyone have info on these non letter coded trannies?
noza
transmission
Post by noza » Thu Apr 09, 2009 1:20 am
can anyone tell me the ratio of these transmission code? 113.301 211H cannot find these on the list..thanks.. :D
