Hey Guys,
I swapped the engine on my 1970 VW Kombi with 091 Gearbox to a Toyota 4Y watercooled motor.
Now this is supposed to be a pretty torquey engine and clearly doesn't like revving much.Revving past 3K rpm , you can feel the gearbox tremble .Honestly It is pretty gruntless for speed but very good for loads.
Problem is , as it doesn't like high revs, climbing hills is painful and slow!I have to maintain the revs at 3k rpm which usually means downshifing to 2nd gear in order not to feel like the engine / gearbox will pop!3rd gear can't handle hills that well either.
I read I could swap the gears to make it match the engine demands.
I was suggested to a 1.14 3rd gear and a 0.70 4th gear.I was advised that this combo would drop the rpms and enable me to move faster at lower rpm thus theoretically utilizing the power band of the engine better.
I am essentially looking at being able to climb hills better / easily and also maintaining descent comfortable rpms at highway speeds.
Question is: Is it worth it to ? I have read that this 3rd/4th gear kombo leaves an annoying gap between 2nd and 3rd and can even make climbing hills difficult as you have to downshift.
Others say better to leave the gearbox as is and just play around with Tire diameter.This option doesn't appeal much to me.
I have also heard that the subbie engines(EJ22 and EJ25) will be a better match and should consider getting one instead.
Basically, gurus, any input or advise on the most reasonable approach without robbing the central bank is welcome.
Which approach?
Transaxle options
- Henryhoehandle
Re: Transaxle options
Going from a 1.26 (stock) to a 1.14 is not a BIG jump. You can go to www.weddleindustries.com and use their free gear calculator and pick anything you need. Just input all of your known data and make whatever changes you want. I would be more concerned with the stock fine-teethed 3rd gear stripping (4th too), so either way, you will probably want to change 3rd gear. If this is a stock transmission, then a superdiff will also be needed.
Thanks for the reply. transmissions are new to me.What would be the advantage of installing a super diff?
- dangerous
94hp at 4400rpm should be a lot faster than a stock type 4.
http://en.wikipedia.org/wiki/Toyota_Y_engine#4Y
I would be fixing the motor before changing the gearbox.
You wont need a super-diff, for that application the stock, 2-spider 091 diff is strong enough,
The super-diff has 2 added spider gears for added strength.
Do you mean replacing the motor or fixing the motor?
- Pablo2
I'll quote what I said on the other forum:
"Don't modify your transaxle because of a poor running engine (trans tremble?). There are a lot of van guys wishing they'd left the gearing stock."
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
