1500 swing axle box mods
Moderator: Henryhoehandle
GARRICK.CLARK
Re: 1500 swing axle box mods
Post by GARRICK.CLARK » Sun Oct 29, 2017 10:32 am
Hi Pablo.
I can do 70, but the revs are a little high . Fast street driving I think the ratios are fine . But any long distance motorway driving its a bit thrashy.
I have a 356 top pulley fitted. This works good.
I do some times do a bit of traffic light drags. So I pre load the box with the hand brake on. NO clutch side steps tho.
gkeeton
Post by gkeeton » Sun Oct 29, 2017 3:21 pm
You're just going to have to get the trans apart, and count the teeth to determine if you have a 3.78. Another thing to consider would be that the splined mainshafts use a different bearing in the gear carrier than the keyed shafts. To put a splined shaft in a your current Type 1 box, you would either need to have the mainshaft turned down in diameter, or obtain a later gear carrier with the correct bearing. A 3.78 is an upgrade to a 3.80, but they cannot be simply interchanged with each other. If you are taking your components to a transaxle shop, they should be able to give you an idea of what else you may need. And yes, I'm a proponent of installing a super diff, but Pablo is a fan of double snap ringing a stock diff, and using the 15 tooth side gears with two 10 tooth spiders. The 15/10 combo may be your least expensive option.
petew
Post by petew » Sun Oct 29, 2017 5:05 pm
Hi Garrick, as I suggested on the Cal Look forums, there is a better base transmission to start with. This is the late 1300 swing trans that starts with an AB code. You should be able to find plenty of them in the UK. I know you guys got lots of 1300s in the 70s. A good core only cost me $250 (pittance). My trans builder told me with only a few mods it was good for over 150hp behind my turbo engine, as long as I didn't do burnouts or sidestep the clutch. Here are the mods it got...
Billet side covers
Decent superdiff
Steel shim plate between the front housing and nose cose
I had it built with the stock 4:12 for short course club racing, but if I had my time again I'd have gone a 3:88 for the freeway. Although, freeway driving is not terrible. The motor comfortably does 3400rpm at 70mph and 3200rpm at 60mph. Yes it's noisy but even if you dropped it down under 3000rpm, I still think you'll want earplugs if the trans is strapped down in any proper way.
This trans cost $AU2500 to have built. Should be slightly cheaper for you.
On the subject of LSDs. I dearly wanted a quaife. Oh man. I still want one, but it's fine with the superdiff for 99% of driving and about 80% of khanas I do with my car club.
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Oct 30, 2017 11:00 am
So with an AB box I could swap the 4.37 ring and pinion for my 4.12 ring and pinion . Fit a Super Diff. Get a Side Cover, Steel plate, hardened keys, weld the 3rd and 4th hubs if the AB gears aren't already. Maybe use the 3 and 4th from my type 2 box If they fit.
Its more complicated than engine building. Respect.
petew
Post by petew » Mon Oct 30, 2017 3:26 pm
This is the specific info David Butler gave me re the AB box...
At a suggestion, the 1300 twin port gearbox is about twice as strong as the 1500, and just a nose cone change with steel thrust plate will do you a long time. It comes with stronger diff internals, steel forks and does not need welded gears or hard keys since it has splines and furnace brazed 3rd and 4th gears.
Specifically you want an AB box with it's numbers finishing in 3 or 4 (1973-74). I'm fairly sure it's a 4:12 from the factory.
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Oct 30, 2017 3:35 pm
O Yes. Sounds good this Pete. I'll definitely be on the look out for one. Should be loads of those over here.
Are the steel thrust plates easy to come by. Who sells them.
petew
Post by petew » Mon Oct 30, 2017 3:37 pm
http://www2.cip1.com/ProductDetails.asp ... D5058%2D10
I'm sure others will have it too. Any decent gearbox builder should stock them.
dangerous
Post by dangerous » Mon Oct 30, 2017 10:43 pm
AB trans has a 4.373 diff ratio standard.
GARRICK.CLARK
Post by GARRICK.CLARK » Tue Oct 31, 2017 3:16 am
Yes , I might have to change it
petew
Post by petew » Tue Oct 31, 2017 3:19 pm
Thanks for chiming in mate. Love your work. :)
