torque that nut.
Moderator: Henryhoehandle
greggholmes
torque that nut.
Post by greggholmes » Tue Dec 05, 2017 10:27 pm
this is from my little commuter car, It seems after i replaced the stub axle i neglected to double check the torque on the axle nut. this is what happened. Remember even if you are tired and its late and you just need to get it done so you can go to work in the morning, give those nuts and bolts a quick double check. here is a link loose axle nut
UKLuke72
Re: torque that nut.
Post by UKLuke72 » Fri Dec 08, 2017 10:12 am
And install the cotter pin ;)
