091 6 rib gearbox question
Moderator: Henryhoehandle
lakis1982
Post by lakis1982 » Fri May 18, 2018 4:39 am
Hello,
i have a 091 gearbox code DK that i plan to fit on my karmann ghia using the nose conversion kit from Weddle industries. Those 091 gearboxes as far as i know are considered to be very tough and durable. My ghia uses an oxyboxer turbo EFI engine of around 280PS and 320Nm (street use only).
The DK gearbox has a 4.57 ring-pinion , 1st 3.78, 2nd 2.06, 3rd 1.26, 4th 0.82
My question: If we suppose that the gear ratios are suitable, could you tell me how much abuse those gearboxes can handle ?? Could i use it as is in stock form without major problems ???
Thank you in advance
Pablo2
Re: 091 6 rib gearbox question
Post by Pablo2 » Fri May 18, 2018 9:01 am
I hesitate to guess at how you drive your car, but I will point out that the VW engineers went with stronger 3rd & 4th gears in the later waterboxer transaxles.
https://www.thesamba.com/vw/gallery/pix/1400261.jpg
aka Pablo, gears, Geary
9.36 @ 146 in '86
