Convert IRS Transmission 2 SA Transmission
Moderator: Henryhoehandle
CaptHWd01
Post by CaptHWd01 » Wed Jun 06, 2018 10:16 pm
I have a VW Trike I'm building and I took out the SA Transmission and notice in the bottom of the case there is some damage. i'm not sure i can use this case. SO i have a Spare IRS Transmission can i convert it to a SA Transmission to fit in the rear end?
how do i put in PIcs saying there to big?
Casting Timmy
Re: Convert IRS Transmission 2 SA Transmission
Post by Casting Timmy » Thu Jun 07, 2018 6:45 am
If it's a dual side cover IRS you can convert it. Measure the backlash on the IRS and then shim it back to that when that ring gear is on the swing diff.
