What Not To Do
In our 2007 Carrera Panamericana run, we had the almost unprecedented incident of both rear wheel axle nuts failing us within the first two days of racing.
Both nuts were brand new, from CB Performance, and advertised as strong, hardened, and better than the stock nut.
The symptoms were the threads on the nuts just failed. It literally cost us a win. We were running mid-pack of over eighty cars at the time, leading in our class, and gaining on the overall.
I had some sharp words with CB Performance, who took the position that they had one more better grade of nut we should have bought.
But, it appears the nut failure may have been our own fault. Not absolutely sure, but probably. We went down with quick-release pins in the axle nuts rather than a proper steel cotter pin. These pins have been popular with some off roaders, and seem to solve the problem of faster drum or disk removal.
After long deliberation, it is likely the pin allowed enough movement to let the axle nut slightly loosen, and the threads were gradually damaged by this.
Our team first discovered loose axle nuts on the second day of the week-long race, hastily retightened the nuts, and by the next day both nuts were worse. We finally lost a wheel, damaging the axle. We were out two days of seven for repairs.
Prior to the trouble, we had posted three days of podium finishes (top three to finish in class), and were working our way into the leading cars, for overall position.
Moral to the story. Don't risk the spring pins. Stick with the cotter pins.
FJC
