Alternator
Moderator: 2088 bob
Booky
Alternator
Post by Booky » Tue Jul 24, 2018 9:47 pm
Old alternator was putting out 17.35 volts way to much.Put on new alternator it’s putting out 15.15 is that ok.All with using multimeter.
Dale M.
Re: Alternator
Post by Dale M. » Fri Aug 03, 2018 2:22 pm
It's a little high but probably with in limits....
Dale
Lives his life vicariously through his own self.
66brm
Location: Perth, Western Australia, The Southern Hemisphere
Re: Alternator
Post by 66brm » Sat Aug 04, 2018 2:31 am
It's important to take into account the condition of the battery and wiring, normally the regulator will limit output to 14.4v. If the battery is questionable or the wiring has higher resistance then the alternator will run at maximum capacity
