LED light problem
Moderator: 2088 bob
Re: LED light problem
Post by Piledriver » Sun Jun 11, 2017 2:35 pm
The marine brass ones work well, although you need a battery terminal reamer as the inside finish is as cast.
Any auto parts store should have the crimp tool for terminal ends on battery cables.
(not a loaner, for use there)
The marine style use a 5/16" stud connection rather than the lame strap clamp setup, so the cable gets a crimped on terminal.
tattooed_pariah
Contact:
Post by tattooed_pariah » Mon Feb 05, 2018 8:53 pm
I may have misunderstood the problem, so let me make sure I'm clear..
OP is trying to use a dual filament bulb where the factory had a single filament.
If that is the case, you may need a universal trailer adapter. They run about $20 at walmart or any parts store. It basically is a box with a diode in it that will allow you to use a single dual filament bulb as brake/tail and turn signals.
-pariah
"I never trust a fighting man who doesn't smoke or drink or at least cause a little trouble." -Admiral William Frederick Halsey Jr.
1972 VolksRod Build Thread
Dale M.
Post by Dale M. » Thu Feb 08, 2018 11:01 am
Aaaah.... No.... Double contact bulb, STOP & TAIL in double contact STOP & TAIL lamp socket, one half of bulb works fine (STOP) other half of bulb (TAIL) does not... Socket problem or bulb problem, that is the question... Most people are leaning towards poor connection in socket...
Dale
Lives his life vicariously through his own self.
tattooed_pariah
Contact:
Post by tattooed_pariah » Wed Feb 28, 2018 12:49 pm
ahh, ok, yeah if you can hook up the bulb in another socket or test bench you can determine if the leds are bad or not.. otherwise I would guess wiring/connection.
Dale
-pariah
craigpeter
Post by craigpeter » Thu Sep 06, 2018 12:10 pm
There have some good LED lights I think. I have been using TerraLUX Light Sart 180 for long time. Color- Black, Bulb type- Light emitting diode (LED).
andy198712
Post by andy198712 » Sun Sep 09, 2018 3:55 pm
Piledriver wrote:
Thu Mar 30, 2017 4:45 am
The socket/ground locating notches tend to corrode, where the little side nubs lock in//connect...
Its usually only pot metal (zinc alloy) even if chromed, it will corrode over time even if kept dry just from humidity
once you scrape them clean put a dab of silicone dielectric grease on everything to preclude further corrosion. (unless you can score the magic stuff the military uses these days, haven't looked if they sell it on ebay. Yet...)
got a picture or name?
