Photo Gallery - Hall of Fame & Hall of Shame
Moderator: 2088 bob
kiaora
Post by kiaora » Tue Jan 16, 2007 7:37 am
Any 1958 - 60 pics of behind the dash ?
I need to check some wiring.
Ta
takotruckin
Post by takotruckin » Tue Jan 16, 2007 4:11 pm
spaghetti, spaghetti....
all i added were the gauges, im currently trying to decide whether to rewire the whole thing, or add an auxilary panel for my stuff, lights etc.
2088 bob
Post by 2088 bob » Tue Jan 16, 2007 5:17 pm
Tako come on take the plunge rip that crap out of there put a nice tidy little panel in there :wink:
MNAirHead
Post by MNAirHead » Tue Feb 13, 2007 1:47 am
72bajaben
Post by 72bajaben » Tue Feb 13, 2007 1:51 am
hahaha mine wont look like that for long.
DesertGuy
Post by DesertGuy » Tue Feb 13, 2007 2:01 am
Here is what the car looks like now, soon to be removed. Killer deal coming on a harness and gauges......
72bajaben
Post by 72bajaben » Tue Feb 13, 2007 2:03 am
that doesnt look to bad at all. why you getting rid of it?
2088 bob
Post by 2088 bob » Tue Feb 13, 2007 5:57 am
DesertGuy you may very well be able to reuse your existing panel with a little cleanup and just build yourself a new harness and tidy up the gauge cluster
2088 bob
Post by 2088 bob » Tue Feb 13, 2007 6:02 am
MNAirHead wrote:Image
OUCH!
i see 2 major infractions allready the green wire heading thru the hole with no grommet and the uninsulated splice just hanging there
save the little 6 circuit panel don't pitch it you can re use it
MNAirHead
Post by MNAirHead » Tue Feb 13, 2007 6:19 am
kiaora wrote:Any 1958 - 60 pics of behind the dash ?
Ta
I have a 60 shell.. and the bentley.. what do you need exactly?..
Welcome to STF
Chaos
Post by Chaos » Mon Feb 19, 2007 9:28 pm
I will post my spaghetti.....and the start of the fix this weekend.
MNAirHead
Post by MNAirHead » Mon Mar 12, 2007 6:40 pm
2088 bob wrote:I typically use a 1" conduit run thru the tunnel just because this give me enough room to run all the circuits in one conduit it is a bit of a pain to get it done
this is one of the methods of getting out of the tunnel in a buggy in a sedan i usually come out of the tunnel on the side so it puts me more in the battery area
this a typical front entrance to the tunnel in a steel bodied sedan i jump into the tunnel ahead of the front firewall ...don't forget a grommet for your conduit
none of these methods are set in stone they are just suggestions
this is a typical entrance into a front area on a stock bodied car or a baja
MNAirHead
Post by MNAirHead » Tue Mar 13, 2007 12:41 pm
CopperBaja wrote:Here's some pics to bring you up to date on my install.
Here's the rats nest I started with...
I started by yanking out ALL the wiring.
Then cleaned things up a bit. Have to eat off a clean plate, right?
After I received the kit, I laid it out.
Figured I should start with the fuseblock. This is the best piece of the kit, IMO. You can buy it at Jegs or Summit, I believe.
I fabbed a piece of 10 gauge and rounded the sharp corners, then gave it a shot of silver rustoleum.
A closeup view, before I rounded the corners
MNAirHead
Post by MNAirHead » Thu Mar 22, 2007 11:45 am
Skidmark wrote:
:shock:
Jerry D
Post by Jerry D » Sun Mar 25, 2007 8:55 pm
Here is my "now you see it now you don't" flip down fuse panel that I built for my Manx.
Jerry...
