Alternator wiring
VW_Man_87
Alternator wiring
Post by VW_Man_87 »
Ok I have a 2 wire alternator and Ive seen people with the same one that has a ground wire on it. Is that ground wire needed and where does it connect to?
Jeremy
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
Re: Alternator wiring
Post by Marc »
The ground wire isn't really needed since the alternator should be in direct physical contact with the pedestal/engine. It's a legacy of the externally-regulated alternators, where it did serve a purpose by assuring that the alternator and regulator were clamped electrically, but on an internally-regulated alternator there's no need - about the only difference you might notice with/without it is a slight change in the warning light action, and then only when there was a poor ground path from alternator to engine and body.
If it were needed for the charging system to function it'd have to be the same gauge as the B+ wire.
sideshow
Post by sideshow »
It's not needed, but I run a brown wire from generator's regulator bracket (body).
