In the newest VW Trends (January, I think) they install an MSD ignition kit, with distributor, box, coil, and plug wires. Do any of you have one of these? Does it really give almost a 30 HP increase? Also, how much does it cost?
Thanks,
-Drew
- [email protected]
-SouthEast Aircooled Volkswagens
MSD Ignition Price
MSD Ignition Price
I installed a MSD 6A and tach adapter about a month or so ago. I needed the tach adapter because I have a 79 with fuel injection. I didnt use there distributer, the stock distributer works just as well for much less $$$$$. You will need to drill two holes in your cap though. Check out the super beetles only site for all sorts of good info on this subject. I did get a noticable increase in power and my gas milage jumped from 26.5 to 30.5 m/gal!!! Good luck.
oh the price - The MSD is about $130 - Check out the CDI at Aircooled.net it much less expensive. There seems to be strong opinion about MSD - CDI ignitions but either way you cant go wrong!!!
[This message has been edited by Go-Dawg-Go (edited 11-29-2000).]
- danielzink
MSD Ignition Price
<< You will need to drill two holes in your cap though. C >>
why is this ? I run an MSD 6AL box with a blue coil and 050 dist w/Pertronix - Jacobs plug wires and I was never told about drilling holes in the dist. cap. Please elaborate.
Dan
Dan
MSD Ignition Price
as I understand it, when or if you widen your plug gap, which you should to gain max preformance from a CDI - you run the risk of crossfire. Check out the post on Super Beetles Only for some great info.(go back about 5 pages)
