1963 VW Baja Bug For Sale (in Colorado Springs, CO)
Well built, period (80s) Baja.
Exterior:
• Roof scoop with functional oil cooler
• Beefy custom built aluminum rear wing/engine cover
• Beefy Double Tube Front/Rear bumpers and Side Nerf Bars
• Factory crank Sunroof, closed – needs cables
• 1 piece front end, comes off with Dzus fasteners and R-clips.
• New headlights, turn signals, new bulbs in tails
• 1 Piece Window Glass – all side windows custom factory type grey tinted (not film)
Interior:
• Roll cage – tied to front beam and rear suspension
• Period Formuling France steering wheel
• Durable Poly Race seats
• G-Force 5 point Camlock harnesses
• Custom Aluminum dash panels and Glove Box door
• Vintage Empi Shifter
• Jamar Parklok
• Hydraulic steering brake
Chassis:
• Reinforced, longer shock front beam, beam stiffeners
• Wider, 3x3 boxed rear trailing arms
• Long travel front and rear shocks
• 091 Bus transmission
• Solid Trans Mount
• Rack and pinion steering
• Completely Rebuilt Brakes
o Turned drums
o New shoes
o New cylinders
o New hardware
o New front hoses
o Late model 2 circuit master
o Park Lok Hydraulic parking brake
o Single lever hydraulic steering brake
• Freshly packed NEW Wheel Bearings
• BFG MT 30” Tires (old)
• 15 x 7” White Spoke Wheels
Engine
• NEW Build
• NEW FACTORY VW CASE!
• Scat Forged Chromoly Volkstroker 74mm Crankshaft
• Thick Wall 88mm Pistons & Cylinders (Old School CIMA)
• Pocket Ported stock valve heads – NEW
• NEW Norris 336S Cam (can upgrade to 1.25 rockers later if you want more hp in future)
• SCAT Solid Rocker Shaft
• SCAT Single High Rev Springs
• Doghouse oil cooler, plus spin-on remote filter and rooftop cooler (5+ quarts in system)
• Ceramic coated $300 exhaust
• Single (Italian) Weber 40IDF on Cast Intake
• Pauter Rebuilt rods (sized, balanced, new bolts)
• Berg oil pump & Cover
The engine build alone on this car would cost $4000+, but is a great engine to turn the big tires and Bus gearbox. Much, much better than a common and cheaper alternative 1835 or 1776 engine with the longer stroke and a quality forged 4340 Chromoly, counterweighted crank.
Awesome, high level build from the 1980s. Body appears to me to be 1964, but titled as a 1963. Clear Colorado Title. Unlike a lot of ‘Bajas’ out there that are just front and rear fiberglass clips – this one was built from the ground up to be functional on and off road. It has seriously beefed up long travel suspension front and rear, a roll cage, 091 Bus transmission, brand new built engine, etc. Front beam is custom built, with long travel shock mounts (provision for two per side, just running one), front spindles are very reinforced, rear arms are custom boxed units with long travel shocks that go through the body and mount to roll cage – provision to add another one or two shocks per side! Polyurethane bushings all around. Center mount rack and pinion steering. Because of how it is mounted, it *does* have some bump steer – this is my first serious Baja, not sure if that just comes with the territory, or can be fixed by slightly relocating the rack. For daily duty, it would need a little more detail work, but the basis is all there and it runs and drives great.
The stroker engine is perfectly matched to the 091 box and larger tires – it is a much more expensive build than an 1835, but the longer stroke (and balanced and counterweighted chromoly crank) really pays off! Built with a NEW Factory AS21 case, new heads, new Scat 74mm crank, Pauter built rods, Norris cam, CIMA thick wall 88 pistons and cylinders, single hi-rev springs, pocket-ported heads, single Italian Weber 40IDF intake with true off-road air cleaner, etc.
Five point camlock harness belts. One piece front end with fuel tank fill through hole, beefed front firewall plate, Steering brakes, Parklok, one-piece door windows, door and quarter windows tinted glass (the glass, not a film tint), Roof scoop oil cooler, more.
I will take $4800 as it sits before going through more of it.
Lights need wired, connect oil cooler and remote filter, detail stuff like that. Then I will ask $5500. Willing to sell without engine for $3000.
[Partial trades considered – other VWs & old Audis – Rabbit/Scirocco/Jetta/Fox/4000 etc, Bus, Vanagon, Type 3, Type 4, etc. or Porsche parts & cars – Wheels, Carburetors (Weber/Zenith/Dellorto) steering wheels, Recaro seats, 924/944/914/912/911/928 – even consider motorcycles - just ask!]
1963 Baja Bug - Caged, 091, New Stroker Motor, etc.
Re: 1963 Baja Bug - Caged, 091, New Stroker Motor, etc.
Offers/Partial trades?
- Leatherneck
That is a really nice looking Baja, money on it is good just not a good time to sell.
Thanks - I agree. Just the wrong time to rely on buying and selling to pay the bills until the new company is up and running!
