MS3X + TheDubShop EFI setup
Moderators: Daniel G, david58
mrblyoung
Post by mrblyoung » Wed May 31, 2017 2:10 pm
Hey Guys,
Thinking about doing something a little different on my spare motor (single TB turbo) and am gonna throw this setup up for grabs to see if anyone is interested in it before throwing it up on TOS.
-NEW Megasquirt MS3X v3.57 with Map Daddy addition for constant barometric change - $800
-Also have both MS3X 18" harnesses
-Tuning Cable and USB adapter
-CB 48mm Throttle Bodies without injector bungs - $450
-Have slightly used air cleaners, air cleaner bases, velocity stacks and hex bar linkage for an additional $100 if wanted
-CB EFI manifolds with inboard injector bungs - $100
-4 NEW Accel 30# Injectors with CB Fuel Rails and CB mounting hardware - $150
-TheDubShop full wiring harness with all sensors - $500
-Wasted Spark with LS2 Coil Pack upgrade - easily changed for sequential ($120 upgrade)
-LS2 Coil Packs with TheDubShop mounting brackets ($175)
-CLT, TPS, MAP, IAT, VR wiring for Crank Trigger ignition, Fuel Pump, Injectors
-All required sensors ($70)
-TheDubShop Hidden Crank Trigger ignition setup (Pulley, VR sensor, sensor bracket) - $200
-Innovate LC-2 Wideband with Gauge - $150
-CB Tee for bottom of Fuel Tank with 5/16 barbs - $20
-Airtex E2000 Fuel Pump and Bosch Fuel Filter (both new in box) - $125
The ONLY things missing from a complete kit that I do not currently have spares of - a Fuel Pressure Regulator, Spark Plug Wires and Hard Fuel Lines. Add a cam sync and you are ready to bolt on a fully sequential setup!
Asking $2400 for the whole kit. Or willing to possibly part out if people want certain bits. Send me a PM if you have questions. Located in Turlock, CA. Consider that a kit like this will run you $3400 if purchased new! Don't have pictures of the parts right now as they are all sitting in a box on the shelf, but can send pics to those who are interested!
trapnm
Re: MS3X + TheDubShop EFI setup
Post by trapnm » Wed May 31, 2017 2:43 pm
This is an amazing deal if you've been considering a setup like this.
mrblyoung
Post by mrblyoung » Tue Jun 27, 2017 12:54 pm
Bump.
Who is online
Users browsing this forum: No registered users and 1 guest
