Mini Cam Sync
Moderator: Tom Notch
MarioVelotta
Contact:
Re: Mini Cam Sync
Post by MarioVelotta » Thu Aug 28, 2014 1:35 am
Here is a pic as I was assembling the first production run of Mini Cam Sync's. What a roller coaster it had been to this point :shock:
I'm working on the next batch now since the demand is still really high.
If anyone else wants to get in on round two you can go here - http://thedubshop.goodsie.com/mini-cam-sync
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
luftvagon
Re: Mini Cam Sync
Post by luftvagon » Mon Oct 06, 2014 10:03 am
Mario,
On that note, are you done making Type4 crank trigger kits?
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
MarioVelotta
Contact:
Re: Mini Cam Sync
Post by MarioVelotta » Mon Oct 06, 2014 11:50 am
Not at all. I should have 10 more in the next couple days. The trigger wheels are being counterbored as we speak.
luftvagon
Re: Mini Cam Sync
Post by luftvagon » Wed Oct 08, 2014 6:42 pm
Are you also planning Mini+Cam+Crank Sync? :)
MarioVelotta
Contact:
Re: Mini Cam Sync
Post by MarioVelotta » Thu Oct 09, 2014 3:02 pm
luftvagon wrote:Are you also planning Mini+Cam+Crank Sync? :)
Yes, I still plan on doing those.
I work on it here and there as they are requiring an almost ground up redesign to keep it compact. I think it will also have to be 2 pieces to access and install the trigger wheel since it will not slide through the shaft seal that I incorporated into the current model. That isn't a feature I want to give up. Nobody likes oil leaks.
aircooledtechguy
Re: Mini Cam Sync
Post by aircooledtechguy » Fri Nov 21, 2014 11:36 am
User update:
I've been running one of Mario's cam syncs on my full sequential MS3X controlled 2056cc in my Squareback since late August. It's performed flawlessly while racing at Bonneville and in daily use since then. I could NOT be happier with it!!
Just buy it; You know you want it!! 8)
MarioVelotta
Contact:
Re: Mini Cam Sync
Post by MarioVelotta » Sat Nov 22, 2014 7:05 pm
Thanks Nate!! I'm glad you are happy with it 8)
I have been hard at work building more! Here are some pics from my second production run. These will be shipping during this next week. I though 30 would have been enough this time, I was wrong. You VW EFI guys are insatiable :mrgreen:
thedrew
Re: Mini Cam Sync
Post by thedrew » Fri Apr 17, 2015 5:25 pm
anyone have a mini sync sitting around they want to sell me? Theres a bit of a wait before the next batch is run and I want one now!
kangaboy
Re: Mini Cam Sync
Post by kangaboy » Mon May 04, 2015 8:07 pm
When is the next round of mini syncs? Figured I would just ask here where everyone can see, apposed to clogging up your inbox.
Also, any word on the cam+crank sensor that you (Mario) were messing around with?
MarioVelotta
Contact:
Re: Mini Cam Sync
Post by MarioVelotta » Mon May 04, 2015 9:08 pm
They are a couple months away. But I am taking pre orders. The machine shop has a 6 week lead time as of now and I need a coupe weeks to get them assembles and tested.
I really wanted to get the new ones into production but everyone has kept me too busy. A good and bad problem to have at the same time :mrgreen:
Here is a 24-1 I had wire EMD cut. This is super tiny and super precise and also expensive.
Here is the scope shot, to bad it doesn't pick up the 1st tooth so well. So the 12-1 will have to do, I can get an 18-1 though that would probably work great but I think that would limit some ECU's options.
Anyway, I am taking Pre-orders for the next run of Cam Sync's. If anyone is interested and want to secure one, just drop me a PM :)
Re: Mini Cam Sync
Post by Piledriver » Mon May 04, 2015 9:30 pm
Did you try it with a "filled in///wide" missing tooth? (Rather than ground out/missing)
Made all the difference on my smallish 36-1 (OK, 36-2, but it was a welding accident) wheel.
The tooth pitch I'm running is little wider, and with pointy teeth.(its a $10 (in onsies/retail) steel spur gear for an RC truck)
I can probably weld that up for you as needed, at least so you could validate it works/not.
(hell, I can even test it)
Fiatdude
Re: Mini Cam Sync
Post by Fiatdude » Mon May 04, 2015 10:22 pm
Electromotive was always saying the smaller the wheel the less rpm you can run -- something like a max 7K on a 5" wheel -- have you tried spinning that up around 7-8K and looked at the signal???
MarioVelotta
Contact:
Re: Mini Cam Sync
Post by MarioVelotta » Mon May 04, 2015 11:11 pm
Piledriver wrote:I can probably weld that up for you as needed, at least so you could validate it works/not.
Thanks Pile, I can weld it up to verify that. I have 2 to work with. What other brands can read a 36-2 though? I need them as universal as possible with the least amount of parts 8)
Fiatdude wrote:Electromotive was always saying the smaller the wheel the less rpm you can run -- something like a max 7K on a 5" wheel -- have you tried spinning that up around 7-8K and looked at the signal???
The above would be 7k at the crank
Re: Mini Cam Sync
Post by Piledriver » Tue May 05, 2015 12:02 am
The 36-2 was an accident of welding settings, and a tooth unexpectedly wilted. :oops:
(didn't undo all the MIG pot settings for TIG w/remote, so 2T mode ramped to full current rather than following the pressure sensor under my thumbs signal)
I suspect most ECUs can read a 36-1.
A MS2e or MS3 would be fine with a 36-4 and maybe more, but its a lot more flexible than many "high end" ECUs...
7K max on a 5" wheel?
That's an Electromotive sensor limitation. Probably.
I tested the ~1.25" 36-1 I'm working with to >17K shaft RPM on a die grinder with my "home made" Hall sensor.
(literally as fast as I could spin it)
MS3 has no sync issues with it at least, or timing lag as far as I could see with the timing light.
(read ~nothing but junk with a ground out tooth tho)
I have machines at work that read 75K on a 10mm shaft with fine teeth ground on it.
Using a Hall sensor. (an expensive one I'm sure)
MS1 has an issue with very high tooth count wheels and max RPM, perhaps Elecromotive has similar hardware limitations?
Probably has a lot>mostly to do with the sensor used.
The one Electromotive sells is many (semiconductor design) generations old, it is a general purpose industrial unit.
Devastator
Re: Mini Cam Sync
Post by Devastator » Fri May 08, 2015 9:05 am
MarioVelotta wrote:They are a couple months away. But I am taking pre orders. The machine shop has a 6 week lead time as of now and I need a coupe weeks to get them assembles and tested.
Could you use a shape like that on the end of an IRS drive axle? I've made these shafts before, but don't know if the depth of the grooves is deep enough to work. Also, you might consider having a shaft hobbed for a gear at a gear manufacturer, then have your local machine shop cut them off into disks. I believe it would be cheaper than EDM.
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
