cam and crank trigger combo inside a distributor (megasquirt
Moderator: Tom Notch
dorkie
Post by dorkie » Fri Aug 30, 2013 4:53 pm
I was pre-reading the megasquirt manual and saw this:
So, I got to thinking about it and it just looks so simple. I need to know why it won't work. I need someone to look at what I plan to make and install in an old distributor (a barely used 009) and tell me what I am missing. I know what I am missing so far - a key or pin to time the trigger wheels to the shaft (easy to incorporate at this point). I have a 5-axis laser at my disposal for making the wheels. (I am just bragging about the "5-axis" part the extra axes are obviously not necessary for this project.)
http://images.thesamba.com/vw/gallery/pix/1105162.jpg
http://images.thesamba.com/vw/gallery/pix/1105161.jpg
http://images.thesamba.com/vw/gallery/pix/1105160.jpg
http://images.thesamba.com/vw/gallery/pix/1105159.jpg
http://images.thesamba.com/vw/gallery/pix/1105158.jpg
sideshow
Re: cam and crank trigger combo inside a distributor (megasq
Post by sideshow » Fri Aug 30, 2013 6:22 pm
I love your virtual mock up. Some packaging suggestion, it maybe easier to top load the pickups.
dorkie
Post by dorkie » Fri Aug 30, 2013 9:11 pm
ah yes, excellent idea. I will lay that out tomorrow and see how it looks. Thank you!
miniman82
Post by miniman82 » Sat Aug 31, 2013 11:50 pm
My only question is: You're doing all this work, only to have timing scatter to still look forward to. Why? Put the crank trigger where it belongs, on the dagone crank! FWIW, this is not a new idea. I saw a setup where a guy used an EDIS system on the cam drive (1/2 crank speed means you need a 72-4 pattern and the teeth get really small), but never heard how it worked out. Again, the main reason for going with a crank trigger is spark stability, programmability and accuracy. When done the way you propose, you lose the biggest piece of the pie- accuracy.
dorkie
Post by dorkie » Sun Sep 01, 2013 7:19 am
alright. that is the exact type of feedback I am looking for. the timing scatter is from the slop in the drive tangs/slots?
Max Welton
Post by Max Welton » Sun Sep 01, 2013 9:37 am
I think lash in the pinion interface to the gear on the crank also contributes as does axial movement of the crank itself.
Max
MarioVelotta
Post by MarioVelotta » Mon Sep 02, 2013 9:47 pm
I have been working on a low profile cam sync myself :) Using the distributor drive gear for this is great. A cam sync is lazy and has a wide window it can be used in.
Tell me more about the laser you have access to :twisted:
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
dorkie
Post by dorkie » Tue Sep 03, 2013 5:49 am
Mario, your cam trigger is definitely going to be nicer than mine.
The laser I have access to is a Trumpf TLC Cut 5. A little more info here:
http://www.inconelco.com/e/3DLaser_e/EN_TLC_CUT5.html
I don't know the wattage, but it cuts through inconel extremely fast.
MarioVelotta
Post by MarioVelotta » Tue Sep 03, 2013 7:58 am
That's the most badass thing ever! What have you made with it?
Are you going to build an all one distributor to try for yourself?
dorkie
Post by dorkie » Tue Sep 03, 2013 12:44 pm
I don't get to play with this laser. In fact, not at all. It is usually tied up in cutting jet engine parts (sounds kinda cool to say that, but it really is cutting up pieces for jet engine parts). The older 3-axis laser, I used to program it so I got to play quite a bit.
I have done machining fixture, gage, and special machine design for the past 23 years, so if I was really cool, I would definitely design and build my own complete all in one distributor. I am not, so the plan is to modify an existing distributor and just make the trigger wheels and spacers. It won't be pretty, but I think it will work. If not, I am not out much.
MarioVelotta
Post by MarioVelotta » Wed Sep 04, 2013 4:08 am
dorkie wrote:so if I was really cool, I would definitely design and build my own complete all in one distributor.
Just do it :P
dorkie
Post by dorkie » Fri Sep 06, 2013 8:33 am
got my trigger wheels lasered. i need to clean them up and make 'em look pretty. then i need to make spacers and a cap and knock some holes in the body for the sensors.
http://images.thesamba.com/vw/gallery/pix/1107984.jpg
Devastator
Post by Devastator » Fri Sep 06, 2013 10:22 am
Looks nice! You might also drill a hole, roughly the same dia. as your single tooth, just behind the single tooth in order to counter balance it slightly. It could potentially see 3K RPM.
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
dorkie
Post by dorkie » Fri Sep 06, 2013 11:47 am
I didn't even think about balancing this stuff. Good call. I will definitely drill a hole. Thanks, Devastator. I follow you (stalk?) pretty closely on the internet. I am definitely using you as inspiration for my current build (E85, Megasquirt, etc).
dorkie
Post by dorkie » Fri Sep 06, 2013 11:54 am
Back to the timing scatter issue... I am looking at all of the components that make up the distributor drive. The crank gear, the drive pinion, the distributor tang (?). I measured everything, but since I don't have my engine together, I have to make an assumption. Or two. :~)> The distributor drive tang to distributor drive pinion has .002" slop. The manual calls for .0028/.005" crankshaft end play.
Assuming the crank will rotate the distributor 1 to 1 and then assuming .005" slop in the crank gear to drive pinion, .002" pinion drive tang to distributor clearance, and .005" crank end play for a total of .012" total sloppiness... and with my trigger wheel diameter of 1.75", I get a maximum of .7858° of timing scatter.
Am I completely lost and delusional? I understand the distributor doesn't rotate 1 to 1 with the crank as stated above. I only used that as a simplification. It actually makes the error worse, I think. I have always been under the impression that there is plenty of timing / spark scatter at idle. This doesn't bother me. I don't care about idle quality like the fella's over on the samba. If it will idle without me touching the gas pedal, I am good. Idles like an NHRA Pro Stocker? Even better.
