cam and crank trigger combo inside a distributor (megasquirt
Moderator: Tom Notch
Redline Weber
Cam and crank trigger combo inside a distributor
Post by Redline Weber » Sat Mar 29, 2014 10:51 am
First, in the states we sometimes "melt magnetic flux" as you in England break biscuits.
Second, I too worked with those at the original ECU-332 project, I raced a Lola-332c F-5000.
That purpose was to educate them on the use of my 60-2 TW.
Today the "gear down" solution effects older engines when used with a modern EOM EMS.
The concept of an internal (inside the ECU) board mounted LASER counter connected with a light pipe to an
engine TW is another method to accurate measure crankshaft position.
THUS my above disclosure.
Lance
Re: cam and crank trigger combo inside a distributor (megasq
Post by Piledriver » Sat Mar 29, 2014 4:16 pm
I'm leaning toward picking up a 48 or 60 tooth wheel to see how much CPU is uses (and the error% delta) vs 12-1 at distributor speed, assuming Mini sends me something to test :twisted:
miniman82
Post by miniman82 » Sat Mar 29, 2014 8:44 pm
What am I supposed to send?
Post by Piledriver » Sat Mar 29, 2014 10:07 pm
miniman82 wrote:What am I supposed to send?
Braaaaaaaaaaains....
I have to stop posting when dead tired, I meant to harass Mario. :oops:
miniman82
Post by miniman82 » Sun Mar 30, 2014 9:18 am
Sorry, fresh out... :lol:
Redline Weber
Post by Redline Weber » Sun Mar 30, 2014 9:49 am
Steve A. has a 48-2 GDTW that should be used with a Hall sensor.
The diameter is about 2.75" though a bit large for a standard 009 body.
He also has the standard 24-1 designed to fit a 009 shaft.
He also has the VR Honda style pickup that fits inside a 009.
Lance
Post by Piledriver » Sun Mar 30, 2014 8:24 pm
I wanted to log the CPU usage (mainloop time) delta between a 12 tooth gear down and a "proper" wheel with a divisible x4 count wheel.
(based on Redline Webers comments)
12 tooth gear down is 6 tooth at the crank speed, so not divisible by cylinder count, perhaps an issue, perhaps not, I ran 6/1 for ages and only changed it to try other setups
I'm currently running a 36-2, so I guess if all else fails I can set my 6/1 setup back up for a comparison.
(or find a suitable 12 tooth steel wheel, my sensor can "see" 32 pitch just fine with a filled tooth, so that should be relatively cheap and easy)
Steve Arndt
Post by Steve Arndt » Mon Mar 31, 2014 3:39 pm
This pic was posted to Powerhaus VW's facebook page. Looks pretty sweet for a drop in solution to triggering.
Corysvdub
Post by Corysvdub » Tue Apr 01, 2014 12:15 am
I was over his shop Saturday when he was putting that motor together
Type 3 Subaru powered EJ25
juki48
Post by juki48 » Sun Apr 13, 2014 8:24 pm
spring is finally here and I've had a few drives with the new ignition and 12-1 optical cam trigger. I am very pleased with the performance while driving. one thing that is annoying is my cranking time is very long from what it was on a distributor. is there a setting I can change to help it fire up quicker? or is this possible a symptom of the cam speed signal?
Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx Style buggy 1600 stock
Max Welton
Post by Max Welton » Sun Apr 13, 2014 8:38 pm
I think it may be "Skip pulses" under ignition settings.
Max
Post by Piledriver » Mon Apr 14, 2014 12:50 am
I actually set mine up now so it cranks for ~2 seconds to build oil pressure.
(priming delay)
It can be set to run batch/wasted spark when cranking for faster fire-off.
You may have to tweak fuel some for this to work well.
(I later went back to the longer crank to build pressure)
juki48
Post by juki48 » Mon Apr 14, 2014 3:32 pm
I think I figured out what is going on. as I've been driving it more it is only slow to start when hot. today it fired right up in the morning but it would crank and crank once hot. I noticed the tach was just kinda bumping and not showing any RPM, then a tiny dim light bulb went off in my head :idea: the resistors in the harness for the cam sensor are hotter so the voltage signal will be lower. I popped off the cover to my MS2 and turned the pot back about 1/4 turn and it fired right up. I'll try setting up the VR signal when hot and see if that is the fix.
Riley
andy198712
Post by andy198712 » Mon Apr 14, 2014 3:53 pm
does timing for idle and crank speed effect hot vs cold starting?
juki48
Post by juki48 » Fri Apr 18, 2014 8:18 am
juki48 wrote:I think I figured out what is going on. as I've been driving it more it is only slow to start when hot. today it fired right up in the morning but it would crank and crank once hot. I noticed the tach was just kinda bumping and not showing any RPM, then a tiny dim light bulb went off in my head :idea: the resistors in the harness for the cam sensor are hotter so the voltage signal will be lower. I popped off the cover to my MS2 and turned the pot back about 1/4 turn and it fired right up. I'll try setting up the VR signal when hot and see if that is the fix.
I'm still having some issues with starting. I want to move my discussions to my wasted spark conversion topic so I don't fill this one up with my issues. viewtopic.php?f=66&t=144696&p=1189482#p1189482
Riley
