MegaJolt ? / twinplugs
Moderator: Tom Notch
WLD419
Post by WLD419 » Sun Sep 15, 2013 2:22 pm
I'm new to this crankfire ignitions , I trying to find out if MegaJolt can be setup to fire Twin Plugs , or is there another system that can do this . I was wondering if the megajolt can fire two edis coil paks . this is for a large bore (103mm) Type 4 heads that I'm thinking of doing twinplugs , thanks in advance Bill D.
Bill DeWitt
2800cc 914-4
TwinPlugs & MegaSquirted
Weekend Therapy :D
miniman82
Re: MegaJolt ? / twinplugs
Post by miniman82 » Sun Sep 15, 2013 2:42 pm
I've heard it's possible to use a pair of EDIS modules in tandem with the Megajolt box, but have not tried it. You might try running each EDIS module with the same VR sensor, or if it doesn't like that maybe you can simply use an EDIS 8 module and a pair of coils?
Jadewombat
Post by Jadewombat » Sun Sep 15, 2013 4:47 pm
I think this was discussed a while back, do a search for Ford Ranger twin plug or something like that here in the Engine Management forum. That is probably the easiest way to go. It's a four cylinder, twin-plug single EDIS module.
WLD419
Post by WLD419 » Wed Sep 18, 2013 4:33 am
Jadewombat wrote:I think this was discussed a while back, do a search for Ford Ranger twin plug or something like that here in the Engine Management forum. That is probably the easiest way to go. It's a four cylinder, twin-plug single EDIS module.
miniman82 wrote:I've heard it's possible to use a pair of EDIS modules in tandem with the Megajolt box, but have not tried it. You might try running each EDIS module with the same VR sensor, or if it doesn't like that maybe you can simply use an EDIS 8 module and a pair of coils?
Thank you , I've tried using the search function & no success ,maybe I'm doing it wrong, I will try some more ,
I've already purchased the trigger wheel, hall sensor & bracket ( type 4 / Mario thank you ) , this will mount behind the pulley on a 911
style shroud , thanks again Bill D.
here's an old picture , it now has CB fuel injection with 48 throttle bodies , old paint :lol: , stock valve covers (less leakage) & some other changes ,
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
Steve Arndt
Post by Steve Arndt » Wed Sep 18, 2013 10:40 am
Bill D. do you have a build thread? I want to know more about your engine!
WLD419
Post by WLD419 » Wed Sep 18, 2013 8:43 pm
Steve Arndt wrote:Bill D. do you have a build thread? I want to know more about your engine!
Hi Steve , sorry I don't really have a build thread, I can give you a few details ? if the moderators don't mind ?
84mm"C" scat crank, 5.7 scat H rods, EMW J-grind cam, pauter 1.48 rockers, 48x38 self ported pos bus heads
with cb vw650 springs & titanium retainers, 103mm JE pistons with 4cc valve pockets & EMW cast barrels,
9.6 cr / .035 deck/ 70cc chambers , bugpack drysump, modified oil passages in the case, ect ect , thank you Bill D.
future plans call for pauter cam & twin plug heads :wink: ,
moderators please feel free to move this post ,
this run is with 48 dells, the dip in the beginning is from me stompping it in 4th gear ,I was supposed to roll into it :mrgreen: , add 18% for flywheel HP,
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
Jadewombat
Post by Jadewombat » Thu Sep 19, 2013 1:58 pm
HAL won't work with EDIS. EDIS needs a VR sensor.
viewtopic.php?f=63&t=138977&hilit=ranger
Wiring up an EDIS to MS or MJ is pretty straightforward though.
WLD419
Post by WLD419 » Fri Sep 20, 2013 5:21 am
Jadewombat wrote:HAL won't work with EDIS. EDIS needs a VR sensor.
Thanks for the heads up :mrgreen: , I guess I got a lot more reading to do & questions to ask :) , thanks Bill D.
the twin plug idea is still in the air , ( need to learn more about it )
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
Redline Weber
MegaJolt ? / twinplugs IGN-1A SURE
Post by Redline Weber » Sun Sep 22, 2013 3:04 pm
The IGN-1A coil that DIY sells requires a "TTL" level signal, this coil has an INTERNAL ignitor.
This coil if used in a single, paired, or even a greater number of "plug(s) per cylinder" will operate with a single channel.
Lance
WLD419
Post by WLD419 » Mon Oct 07, 2013 11:12 am
Ok, I've been doing some reading (research) and the ranger doesn't use edis , it says it runs through a pcm , I could be wrong ,
but from what I've read & saw ( went to the bone yard) or didn't see there is no edis on the ranger, maybe I'm wrong ? ,
Ok , more reading says that the edis8 fires every 90 degrees (8 times in 720 degrees) here again I could be wrong ? the vw fires 4 times
in 720 degrees every 180 degrees, Now what I did find is that some has ran 2 edis4 systems 1 vr sensor on 1 megajolt box with 4 COP,
so I need to find out if that will work with 2 coilpaks ? here's a link to what I'm referring to , about half way down the page there's a drawing, Thank you Bill D.
http://www.autosportlabs.org/viewtopic.php?t=1359
Bill DeWitt
2800cc 914-4
Weekend Therapy :D
Devastator
Post by Devastator » Tue Oct 08, 2013 5:43 pm
Couldn't you run 2 IGN-4 coils and split the signal wires from MS or MJ to each coil?
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
Steve Arndt
Post by Steve Arndt » Tue Oct 08, 2013 5:50 pm
That would work.
I don't see why you couldn't just run two EDIS4 systems off one ECU with one VR sensor.
I have ran two CDI boxes off of a single unilite in the past with no problems.
For the benefits of twin plug though I think you would want to go to direct coil control with eight ignition channels.
Post by Piledriver » Tue Oct 08, 2013 6:09 pm
Ideally the 2 plugs would be set up as leading and trailing, rather than simply be fired at the same time.
You could ~easily use dual EDIS/4 setups with dual Megajolts, each programmed with it's own advance curve to achieve this.
(or a pair of MS1s etc)
There was some discussion to reuse the rotary code on MS3 to achieve the same thing on a 4 banger or possibly even a V8 w/hardware mods, but it didn't make the official "to do" list for MS3v1.3
Steve Arndt
Post by Steve Arndt » Tue Oct 08, 2013 9:37 pm
At that point it's better to get a real ecu that can drive 8 inductive coils directly and skip the expensive smart coils. I am itching to try it with my. Current setup.
Ps as I recall jake raby found equal timing on each plug was best on the t1 and t4.
Post by Piledriver » Tue Oct 08, 2013 10:47 pm
Steve Arndt wrote:At that point it's better to get a real ecu that can drive 8 inductive coils directly and skip the expensive smart coils. I am itching to try it with my. Current setup.
Interesting, last I checked on that he was still playing with it, both@same time makes life easy.
I still can't afford the T4 second plug headwork, and probably will never be able to justify it.
I'm still fond of keeping the ignition noise out of the ECU, and LS2 coils should work just fine.
OTOH remote drivers work fine, many choices, use a pair of waste spark 4 tower coils of your choice with a Quad spark or roll your own.
