MSD 6AL digital
Moderator: Tom Notch
dcd
MSD 6AL digital
Post by dcd » Tue Feb 25, 2014 2:02 pm
hi i have new project engine which is considered of 2276cc engine with web cam 86a 290D with 1.4 rockers the heads are from CB 42x37.5 wedge port cnc that said that it can make more than 200hp , this thing is going to start with mega squirt 2 ,my big ????? is in MSD dist. it came 6 option for setting the springs which one is for my combo how to start knowing which one is the best performance could give ,10x a lot who can give some advice....
Steve Arndt
Re: MSD 6AL digital
Post by Steve Arndt » Tue Feb 25, 2014 3:09 pm
Wedge ports (huge port volume) with the Web 86A is a bit of a miss match.
What is your fuel choice and what is your compression set at?
Depending on the compression ratio and fuel that will influence the timing curves you need.
dcd
Re: MSD 6AL digital
Post by dcd » Tue Feb 25, 2014 4:00 pm
8.5 to 9 ratio for CR
Steve Arndt
Re: MSD 6AL digital
Post by Steve Arndt » Tue Feb 25, 2014 4:25 pm
You will probably need quite a bit of initial advance (say 14 at idle). Ramping up fairly quickly to all in by 2500 RPMs. Figure 30 degrees +/- 3 under full load. Choose the advance limits and springs to come close to those numbers and you will be in the ball park.
I run the 86A (115LC version) at 12.5:1 compression ratio on pump 91 octane (super sqhish pistons). 40x35 heavily ported heads. I have to really play with the timing map to keep it happy with that compression.
Re: MSD 6AL digital
Post by Piledriver » Tue Feb 25, 2014 7:11 pm
You have a ms2, you can run fully programmable timing using mostly what you have if you wish.
You can run the MSD and even the distributor.
Steve Arndt
Re: MSD 6AL digital
Post by Steve Arndt » Wed Feb 26, 2014 10:33 am
Very true. You can "lock" your MSD distributor and use it to trigger your MS2.
My general timing numbers I gave can still help get your ignition mapping started.
I like the 86A quite a bit. It idles smooth and pulls hard to 6500.
dcd
Re: MSD 6AL digital
Post by dcd » Wed Feb 26, 2014 3:30 pm
ok but i never done locking it can you tell or show how to do it , another ??? what it should be my idle timing degree , and about injectors , do i need low or high impedance how much cc injector is enough to my application .....
Re: MSD 6AL digital
Post by Chip Birks » Wed Feb 26, 2014 3:59 pm
There should be instructions from msd for locking it i would think. High impedance injectors are easiest to deal with. There are calculators out there to help figure our injector size based on your hp goals. Google is your friend. I like to see what is recommended, and then add 15-20% with future hp upgrades in mind. With the right injector, you can have good idle quality and high hp potential. I have 96lb/hr injectors on my turbo'd 2276. It idles nice and lean at 825rpm, yet has the fuel flow to support over 400hp on gasoline if i ever need it too. I'm not saying you need anywhere near this, but a set of 48lb/hr might not be a bad place to start.
Re: MSD 6AL digital
Post by Chip Birks » Wed Feb 26, 2014 4:14 pm
dcd
Re: MSD 6AL digital
Post by dcd » Sat Mar 01, 2014 8:45 am
ok i have decided to lock my dis. and set it from MS2 but what is best idle advance to start ? i know that max advance will be 32degree
Re: MSD 6AL digital
Post by Chip Birks » Sat Mar 01, 2014 10:17 am
Max advance will be whatever your motor wants. 32 degrees is a good max advance with a 009. Yours may differ. Mine does.
I think a lot of us with programable ignitions are in the low to mid teens at idle. Some guys go into the high single digits. It all just depends on your combo.
dcd
Re: MSD 6AL digital
Post by dcd » Sat Mar 01, 2014 11:53 am
so how to start the timing adjustment any info be great , as i told my engine is 2276cc with cb 1410 heads web cam 86a 1.4 rockers MSD 6al digital dist. locked CR 8.5 to 9 range and what is my rpm limit and HP will be and timing max can be set ....
Re: MSD 6AL digital
Post by Piledriver » Sat Mar 01, 2014 4:00 pm
I have 12 degrees of initial at 100 KPA, more cam may want more (and your motor is not the same).
You will also want to add 15-25 degrees if "vacuum advance" (keeps the EGT and CHT down at low maps or running lean of stoich at cruise etc)
That's the base map--- Idle has it's own timing table and VE table, and the the system can tweak the timing in real time to maintain a stable idle speed as well. (as well as a stepper or PWM controlled IAC)
This all assumes you have the MSextra firmware loaded.
