MS1 and tunerstudio timing problem.
Moderator: Tom Notch
maxyray
Re: MS1 and tunerstudio timing problem.
Post by maxyray » Sat Oct 11, 2014 9:09 am
This is what I'm seeing when I strobe with SAW disconnected...
So I think that the timing is fine
Max
Post by Chip Birks » Sat Oct 11, 2014 9:48 am
That is 10° B(efore)TDC :wink:
TS doesn't know if SAW is connected or not. That is the beauty of the edis system. It can go into limp mode even if the ecu has troubles. Your readings are correct.
maxyray
Post by maxyray » Sat Oct 11, 2014 9:52 am
Chip Birks wrote:That is 10° B(efore)TDC :wink:
Yeah sorry I'm very new to all of this.
Thanks for the advise :D
Max
