Crank trigger , wasted spark, locked timing without ecu
Moderator: Tom Notch
68turbofastback
Post by 68turbofastback » Sun Dec 14, 2014 7:20 pm
Anyone know a way to go distributerless with a crank trigger and locked timing?
Re: Crank trigger , wasted spark, locked timing without ecu
Post by Piledriver » Sun Dec 14, 2014 7:44 pm
Sure, put EDIS on it and advance the trigger mechanically to your desired timing.
Default setup "limp mode" gives 10BTDC.
Move the sensor as needed.
Kind of a shame to waste the power of real programmable (boost sensitive) ignition mapping, but is dead simple.
Jadewombat
Post by Jadewombat » Mon Dec 15, 2014 10:41 pm
