Lost Sync
Moderator: Tom Notch
Clonebug
Re: Lost Sync
Post by Clonebug » Tue Nov 17, 2015 9:54 pm
I had a few sync losses so I turned my filter to
Primary tach "On"
Noise filter enabled "On"
Tach period rejection "On"
Time "ms" 0.2
Percentage "ms" 12
Secondary Tach "Off"
I increased them both once but it started missing so I put it back.
vwi_dduvall
Re: Lost Sync
Post by vwi_dduvall » Tue Nov 17, 2015 10:15 pm
Thanks I will give those a try at least I will get a feel for which way it goes worse or better.
Currently running:
Time(ms) .5
Percentage(%) 4
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
Re: Lost Sync
Post by Piledriver » Tue Nov 17, 2015 11:51 pm
Play with the filter period at the top first.
vwi_dduvall
Re: Lost Sync
Post by vwi_dduvall » Sat Nov 21, 2015 7:53 pm
OK I am now cooking with gas or spark for the matter ;-)
I spent lots of time idling in the driveway today and also revving it up to around the 3K range and adjusting the noise filter to get a feel for how each of the settings was affecting the sync. It seemed very little so found what seemed to be best, at the time, settings and then added in a 10k resistor. That made a world of difference even though still get a total of 3 lost sync reason 2, on the last run today, it was very drivable. Not sure if the 3 that happened could be cleared up by going to the 20K resistor or not but might try later.
Here are links to the last run of the day log and .tsproj:
http://volkswageninsanity.us/Postings/F ... OG0018.msl
http://volkswageninsanity.us/Postings/F ... .47.tsproj
Daniel Du Vall
