golf- audi coil /microsquirt spark settings
Moderator: Tom Notch
damo99
Post by damo99 » Fri Jan 15, 2016 5:36 am
hi i have got my microsquirt wired up and comunicating with tuner studio finally (had some earth problems but all sorted now)
i can't find how the ignirion settings go on any of the microsquirt guides (i have a golf / audi 106b coil with igniter ,,4 post wasted spark)
i have spark output set to going high and coil charging scheme at standard coil charging (i think is right )
i am not sure on ignition input capture and cranking trigger
also trigger offset and skip pulses
i have dwell set at 3 and maximum spark duration at 1.5
hope you can help with this
thanks damien
Re: golf- audi coil /microsquirt spark settings
Post by Piledriver » Fri Jan 15, 2016 7:30 am
It would be best to ask (with the coil model or part#) on msextra.coms forums.
But... I suspect you may find the info you seek in the manual.
damo99
Post by damo99 » Sun Jan 17, 2016 6:20 am
well i got all the info from the ms extra pages
i was running standard firmware but was recomended to go ms extra
it has cleared up alot as i couldn't find info on coil settings for the standard firmware
