Fuel mixture sensors
Moderator: Tom Notch
Dean...
Post by Dean... » Wed Sep 27, 2017 4:44 am
I'm sick and tired of thinking I have the mixtures right, but being wrong. I have twin Webers and I would like to know if there are any cheap sensors that I could weld into each exhaust pipe from the cylinders and use a multimeter to see what the mixture is?
Sent from my Pixel XL using Tapatalk
ps2375
Re: Fuel mixture sensors
Post by ps2375 » Thu Sep 28, 2017 10:42 pm
buy one WB and install 4 bungs.
Dean...
Post by Dean... » Fri Sep 29, 2017 5:24 am
ps2375 wrote:buy one WB and install 4 bungs.
Cool thanks for that. This is what I was thinking of doing, but I've been trying to find out how to exactly test for the right mixture and haven't found that info. Do you happen to know if a link where I might find that info?
ps2375
Post by ps2375 » Fri Sep 29, 2017 6:21 am
Not sure what you mean, if you get a WB setup, it will consist of a sensor, a controller and for your needs a display. The controller reads the sensor and sends the readings to the display. There are several companies out there that sell this sort of thing. And people have their preferred vendor, mine is http://14point7.com.
I would make this a temp setup that you can install for tuning and then remove when not.
