Stock FI End Castings from CBPerformance
Moderator: Tom Notch
kangaboy
Post by kangaboy » Wed Dec 06, 2017 4:16 pm
Hey all. I know during my months of research trying to build my FI setup, I can across several others looking for stock FI end castings to no avail. Seems CB got the hint and decided to put these back into production again.
http://www.cbperformance.com/product-p/7360.htm
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
ps2375
Re: Stock FI End Castings from CBPerformance
Post by ps2375 » Wed Dec 06, 2017 5:04 pm
kangaboy
Post by kangaboy » Wed Dec 06, 2017 10:30 pm
The kit that Antonio sells is the Mexican Kit. The endcastings that CB sells is the original DP endcastings with the injector bungs in it. They discontinued it for a while.
ps2375
Post by ps2375 » Wed Dec 06, 2017 10:47 pm
not sure what the difference is.
sideshow
Contact:
Post by sideshow » Thu Dec 07, 2017 7:47 am
The center chunk you want to use;
Carbureted beetle style --> CB end castings
L-Jet beetle style --> OEM steel end castings
Mexican FI --> MX end castings
Flexibility wise the carbureted intakes are the most common and diverse (options), followed by the dual IDF pattern.
