Injector Gaskets for Mexi Manifolds
Moderator: Tom Notch
kangaboy
Post by kangaboy » Fri Aug 10, 2018 10:31 am
Do they make large injector gaskets to allow the use of modern style injectors to fit in the seemingly oversized ports on the Mexican FI end castings? For some reason I thought the Mexican end castings would have the same injector port size as the CB end castings, but I was mistaken. Is finding gaskets the answer? Or should I be looking for the injectors with the fat base?
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
My Megasquirt Turbo Build
Re: Injector Gaskets for Mexi Manifolds
Post by Chip Birks » Fri Aug 10, 2018 11:49 am
Fat base. Kinda limits you for sure. DIYautotune.com used to sell fat based units all the way up to 1000cc. Might be worth a look there.
kangaboy
Post by kangaboy » Fri Aug 10, 2018 9:41 pm
Wish that guy would have checked the ones he is selling in the classifieds and got back to us. Those are the kind I think I need.
Post by Chip Birks » Fri Aug 10, 2018 11:39 pm
https://www.injector.com/cart/pc/Delphi ... -44p42.htm
These are the same as what diy used to sell.
kangaboy
Post by kangaboy » Tue Aug 14, 2018 6:07 pm
Anyone know what size injectors the German end castings use? They look significantly smaller...like the CB end castings.
https://www.thesamba.com/vw/classifieds ... id=2178185
Jadewombat
Contact:
Post by Jadewombat » Wed Aug 15, 2018 9:26 pm
I think what you're referring to is the gasket that goes around the tip of the injector?
There are two for the mexi manifolds, one around the tip and a much bigger one one the body. I have used Bosch 210cc injectors for an older VW VR6 and Bosch 180cc injectors for a Ford? which had the same body size and fit no problems in the mexi manifolds.
The tip gasket is an o ring and the other is like a piece of cut rubber tube.
kangaboy
Post by kangaboy » Thu Aug 16, 2018 8:55 am
Yeah, I guess O-Ring would be the more appropriate term.
Thanks for the heads up on the injectors. I see if I can hunt down a VR6 next time I'm at the Pic-n-Pull.
Steve Arndt
Contact:
Post by Steve Arndt » Thu Aug 16, 2018 10:34 am
The Dub Shop has adapters.
I welded regular injector bungs into the mexican manifold a while back. That gives more room inside for porting too.
