Where is this feature?Piledriver wrote:....if you have ms2-extra you can specify the sample angle and duration to find the lowest vacuum point.
Idle tuning for lowest MAP
- panel
Re: Idle tuning for lowest MAP
basic setup, general/lags, towards the bottom.panel wrote:Where is this feature?Piledriver wrote:....if you have ms2-extra you can specify the sample angle and duration to find the lowest vacuum point.
Assumes MS2-extra 3.xx, 3.1.1 is current stable FW code.
(3.12//um 3.13a is current beta, but it fixed a long standing intermittent single cycle miss for me, effects low tooth count wheels)
