GSXR ITB's
Moderator: Tom Notch
Re: GSXR ITB's
Post by Piledriver » Fri Aug 21, 2015 11:25 am
MAPP gas burns a bit hotter...
andy198712
Re: GSXR ITB's
Post by andy198712 » Fri Aug 21, 2015 1:47 pm
Piledriver wrote:MAPP gas burns a bit hotter...
totally, but sadly my torch is for lesser gasses, a butane propane mix i believe i have... its not my tools list to get a map gas torch and bottle though!
those rails being thin i should have too much trouble i hope!
Dale M.
Re: GSXR ITB's
Post by Dale M. » Thu Aug 27, 2015 8:56 am
If tank connector (1 inch "disposable tank connector" - US style) is same for propane and mapp gas container your torch can handle either gas type....
Dale
andy198712
Re: GSXR ITB's
Post by andy198712 » Thu Aug 27, 2015 2:34 pm
Cheers Dale, I'll take a look next time I'm inthe shop!
Ordered 4 Nippon denso plugs for the injectors.
Currently flatting off the manifold tops to bolt on my plates I'm making.
FPR 3bar arrived today.
Goin to order up my hard lines ect...
Getting there!
Just need to double check how to wire injectors and the tps maybe and I'm good to go I think!
For NA do I just block off the FPR vac port?
andy198712
Re: GSXR ITB's
Post by andy198712 » Fri Aug 28, 2015 11:25 am
Nippon denso "top slot" plugs fit perfect :)
andy198712
Re: GSXR ITB's
Post by andy198712 » Sat Oct 17, 2015 10:09 am
my torch is really struggling to get it hot enough so will be upgrading to map gas.
one fuel rail is done though... pics to follow
andy198712
Re: GSXR ITB's
Post by andy198712 » Sun Oct 18, 2015 12:51 pm
Map gas was amazingly hotter!
first attempt at brazing...
how they'll sit on the engine (all fuel pipes facing backwards) and going to chop off all the excess metal one them
going to try and run the injectors like this with plugs inside the rails instead of outside for more compact package...
Race-buggy
Re: GSXR ITB's
Post by Race-buggy » Mon Jan 25, 2016 5:50 pm
are there any throttle bodies that have 48mm size of motorcycle suitable for conversion for use on VW idf intake.will be on my 2413ccm racing engine type 4
andy198712
Re: GSXR ITB's
Post by andy198712 » Thu Mar 24, 2016 5:17 pm
Well, the ITBs are on and working! Need a bit of hammering to give some clearance to the right hand fuel rail but it all works!
Re: GSXR ITB's
Post by Piledriver » Fri Mar 25, 2016 1:25 am
Race-buggy wrote:are there any throttle bodies that have 48mm size of motorcycle suitable for conversion for use on VW idf intake.will be on my 2413ccm racing engine type 4
42 -45mm are pretty common and either will flow more air than 48 IDAs due to no venturii...
Getting the spacing the same is usually more of a challenge, I have some 42s off a Yamaha waverunner jet ski (R1 based motor) that are flanged true ITBs.... Just welded up std manifolds so the bolts could be installed in the right places.
An adapter plate would have been easier for most.
The TBs themselves are only 60mm tall. The bore spacing is ~perfect.
andy198712
Re: GSXR ITB's
Post by andy198712 » Wed Jun 01, 2016 5:34 pm
https://youtu.be/uBe-zt4c9x0
My ITB cold start up.... Pretty happy with it! No air valves ect
Race-buggy
Re: GSXR ITB's
Post by Race-buggy » Mon Jul 04, 2016 3:59 pm
cool. yes i know that Piledriver,that them flows more then a pair 48IDA. where can i buy this from yamaha waverunner jet ski ITB used ?
i have buy a set from gsxr. I belive them are 46mm butterfly at them i have buy. but i have 2 engines more t4 i want EFI at.
one 2.0 with 1800 heads. with volvo valves. and web 163/86b camshaft. itb for this will be nice with 40mm or some like this i think.
Re: GSXR ITB's
Post by Piledriver » Mon Jul 04, 2016 6:46 pm
They have them on Ebay all the time.
Waverunner 1100
Engine is basically a marine version of a gsxr1000, Itbs bolt direct to head.
Newer versions are probably larger.
