GSXR ITB's
Moderator: Tom Notch
Devastator
Re: GSXR ITB's
Post by Devastator » Thu Dec 06, 2012 1:33 pm
I can't price the new pulley as I haven't determined the exact design. I can tell you the price of the pulley I currently offer in a PM, but want to let you know that it's design may change so I can include a stop. I didn't realize there wasn't a stop until I had a set of ITB's in hand.
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
Vee Dub Nut
Re: GSXR ITB's
Post by Vee Dub Nut » Thu Dec 06, 2012 2:06 pm
Devastator wrote:I can't price the new pulley as I haven't determined the exact design. I can tell you the price of the pulley I currently offer in a PM, but want to let you know that it's design may change so I can include a stop. I didn't realize there wasn't a stop until I had a set of ITB's in hand.
The stop will be fixed to the pulley? Any way to adjust it?
I think the best approach would be to use an adjustable screw stop in the throttle body and not have to rely on the balance/bypass screws for idle speed. Leave those just for barrel to barrel balance.
Fightin' Texas Aggie Class of 2006
67 Beetle
Devastator
Re: GSXR ITB's
Post by Devastator » Thu Dec 06, 2012 2:18 pm
There will be a stop on the pulley and a bracket with an adjusting screw for setting the idle. I'm designing more than just plates....
Sandrail
2276 ACVW
Burning E85
going fast enough."
Mario Andretti
Vee Dub Nut
Re: GSXR ITB's
Post by Vee Dub Nut » Thu Dec 06, 2012 4:50 pm
:mrgreen: Sounds good!
67 Beetle
andy198712
Re: GSXR ITB's
Post by andy198712 » Thu Dec 06, 2012 5:39 pm
if you could shoot me a PM with some rough costs that would be cool!
all very interesting!
Devastator
Re: GSXR ITB's
Post by Devastator » Fri Dec 07, 2012 2:16 pm
I would PM you the cost...if I had any idea what it would be. I still have a quite a lot to design and build. Then I'll price it out. I just finished machining the first side of the lower adapter plates. :wink:
Sandrail
2276 ACVW
Burning E85
going fast enough."
Mario Andretti
andy198712
Re: GSXR ITB's
Post by andy198712 » Fri Dec 07, 2012 5:59 pm
no worries bud, i'm in no hurry :)
i'm just after the pulleys though at the min;)
andy198712
Re: GSXR ITB's
Post by andy198712 » Mon Dec 24, 2012 8:10 pm
Will these take boost do we think?
supaninja
Re: GSXR ITB's
Post by supaninja » Mon Dec 24, 2012 9:19 pm
I haven't tested them with boost yet but the main shafts look to be sealed up nice and tight by design, I don't see why they can't take boost.
viewtopic.php?f=14&t=140387
andy198712
Re: GSXR ITB's
Post by andy198712 » Tue Dec 25, 2012 10:26 am
That was what I noticed too ;)
andy198712
Re: GSXR ITB's
Post by andy198712 » Thu Jan 10, 2013 4:42 pm
finished epoxying up my holes i didnt want!
pics will follow
andy198712
Re: GSXR ITB's
Post by andy198712 » Fri Jan 18, 2013 12:07 pm
http://s40.photobucket.com/albums/e222/ ... 06CF4E.jpg
so here's what i was thinking....
chop the fuel rail in half, use the current feed as my feed guessing i'll just have to fuel clamp that on there, then put a fitting in either open end and run a pipe between the two.
it it will feed to the current spout, then from a fitting, to the other side and dead end there..... simples!!
excuse the link i'm having trouble getting the pics to work!
andy198712
Re: GSXR ITB's
Post by andy198712 » Fri Jan 18, 2013 12:09 pm
thats bigger then i thought!
Clonebug
Re: GSXR ITB's
Post by Clonebug » Fri Jan 18, 2013 4:26 pm
andy198712 wrote:http://s40.photobucket.com/albums/e222/ ... 06CF4E.jpg
You should put the regulator on the end of the other rail to bypass the excess fuel back to the tank instead of being a deadend.
andy198712 wrote:excuse the link i'm having trouble getting the pics to work!
When in photobucket you need to copy the last line of the choices. The one that has the "IMG" tags on each end. Paste that in your post and you are good to go.
andy198712
Re: GSXR ITB's
Post by andy198712 » Fri Jan 18, 2013 4:55 pm
i tried that and it told me about pics not being more then 800 pixels high or something.... will just take landscape maybe...
Well this is the really cunning part!
i'm going to mount the GSXR pump in my tank... which is internally regulated and cooled by the surrounding fuel and runs a dead end system....43psi i think? 8)
