Common car fuel pumps?
Moderator: Tom Notch
Bruce.m
Re: Common car fuel pumps?
Post by Bruce.m » Tue Jan 06, 2015 5:55 pm
Try Tracy Tools (Google it) for NPT taps
andy198712
Post by andy198712 » Tue Jan 06, 2015 6:10 pm
Bruce.m wrote:Try Tracy Tools (Google it) for NPT taps
£6 not bad!! Will look up postage tomorrow at home :)
Thanks!
Clonebug
Post by Clonebug » Tue Jan 06, 2015 8:10 pm
Just make sure you can get NPT brass tee's.
andy198712
Post by andy198712 » Wed Jan 07, 2015 3:37 pm
Clonebug wrote:Just make sure you can get NPT brass tee's.
I'm also wondering if 1/4NPT is like 1/4BSP ect
Or i just buy a swirl tank, seen VW made one from an old golf or something? had an IN, VENT, OUT, RETURN .... can use an 8mm outlet tank piece maybe...
Clonebug
Post by Clonebug » Thu Jan 08, 2015 10:15 pm
That would be too easy :lol: :lol: ....if you could find one.
andy198712
Post by andy198712 » Fri Jan 09, 2015 8:55 am
Clonebug wrote:That would be too easy :lol: :lol: ....if you could find one.
Just thought, what if I could walk into the dealer and buy one! Doubt I'd be THAT lucky mind!!
Clonebug
Post by Clonebug » Fri Jan 09, 2015 10:10 am
I think it was Pile that said they were available at the local "FLAPS".
You could try there too.
Didn't the VW Fox use them???
andy198712
Post by andy198712 » Fri Jan 09, 2015 10:29 am
will have to look into it, need a uk suppler also. seems as easy route to go though!!
8)
andy198712
Post by andy198712 » Fri Jan 09, 2015 10:36 am
anyone know what VW called these things?
squeakie
Post by squeakie » Sat Jan 10, 2015 6:09 pm
I don't know if these are any good (quality), but the price seems right:
http://www.ebay.com/itm/2L-Universal-Al ... 86&vxp=mtr
raygreenwood
Post by raygreenwood » Wed Jan 14, 2015 12:28 am
andy198712 wrote:anyone know what VW called these things?
Are you talking about the fuel pressure accumulator from a CIS injected car?
Post by Piledriver » Wed Jan 14, 2015 4:00 am
I think I mentioned at some point using the plastic sump recirc tank off later Golfs/cabbies/Fox etc.
I think the nomenclature was "filter" or something equally idiotic for a ~transparent hollow plastic enclosure with a bunch of tubes sticking out..
andy198712
Post by andy198712 » Wed Jan 21, 2015 1:01 pm
They turned out to be pretty pricey here in the UK new, around £80 which is about $150??
What about that vent in the corner of the tank, as you look in under the bonet from the front of the car its bottom right, couldn't i just put my return into that??
andy198712
Post by andy198712 » Sat Aug 15, 2015 4:05 am
anyone tried that? or the port in the filler neck? looking to get this rolling next month :)
Jadewombat
Post by Jadewombat » Sat Aug 15, 2015 6:59 pm
I use a Bosch pump off a mid-70s VW bus and the fuel filter. The inlet side of the filter is 6mm I think? and 8mm outlet?? It's smaller on the inlet side than the outlet though.
