Mexican Beetle 1600i Flat spot help!
Moderator: Tom Notch
paullanzarotti
Post by paullanzarotti » Sat Dec 13, 2014 4:12 pm
I have a 1998 Mexibug that is suffering from a pronounced flat spot at low revs which makes it not much fun to drive.
I have cleaned out all the breather pipes, replaced Relay 30, replaced the idle control valve and still the problem persists.
I obviously need to get the car plugged into VAGCOM software but I haven't been able to find anyone in London or the UK that has the right software/3 pin plug and experience to help with this matter.
I know Phade is the expert on Mexibugs FI but I haven't been able to get hold of him. Does anyone know of anyone else in the UK (or London) that could help?
Thanks in advance people!
Paul
vwjim
Re: Mexican Beetle 1600i Flat spot help!
Post by vwjim » Wed Sep 13, 2017 6:51 pm
Paul,
What was the cause of your flat spot?
Cheers.
Jim
paullanzarotti
Post by paullanzarotti » Thu Sep 14, 2017 1:56 am
After having the ECU chipped by Manfred in Germany and changing every sensor and vacuum pipe I ditched the ECU and distributor for Megsquirt and Wasted Spark and now the car flies! Quite a significant difference to say the least.
vwjim
Post by vwjim » Thu Sep 14, 2017 4:39 am
Blimey, that's an extreme swap.
Before you changed to megasquirt, did you change the factory coil pack & or distributor? wondering if your problem was in there.
Thanks for your quick reply.
Jim
paullanzarotti
Post by paullanzarotti » Thu Sep 14, 2017 4:58 am
Yes - leads, everything. Other people have the same issue - you cannot hold revs steady between idle and 1150 RPM.
My car would idle at 820 and do nothing but lean out a little before jumping to 1150rpm. There was a clear hole in the rev range at low revs. Makes for very lumpy traffic driving!
paullanzarotti
paul_f
Post by paul_f » Thu Sep 14, 2017 11:20 am
When you changed to the megasquirt did you keep the injectors?
Sent from my ONEPLUS A5000 using Tapatalk
Paul H
Post by Paul H » Sat Sep 16, 2017 3:18 am
People seem to start out with the mexican injection and end up changing everything eventually
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
vwjim
Post by vwjim » Wed Sep 27, 2017 3:43 pm
New coil pack, now runs lovely.
paullanzarotti
Post by paullanzarotti » Mon Oct 09, 2017 4:34 pm
Hi Paul - sorry for the very late reply - don't get notifications when I get a message annoying and hadn't checked back in a while.
Yes, I kept the same injectors and most of the original wiring loom. I could have kept the distributor but decided to remove it and go with wasted spark set up.
The car runs lovely, lots of power and evenly distributed through the rev range. The original ECU was fine but there were flat spots all over the place.
