Throttle body ball joint linkage
Moderator: Tom Notch
sidemarkers
Post by sidemarkers » Wed Sep 07, 2016 12:53 am
Who sells an adapter that allows a ball joint style throttle body to mate up to a VW style throttle cable? Thanks in advance.
Re: Throttle body ball joint linkage
Post by Piledriver » Wed Sep 07, 2016 3:27 am
Most auto parts stores, and good hardware stores will have the snap on clip and the ball set up.
Look for one with a setscrew on the side to clamp cable.
If you cant find that type, get one with a small ID and drill and tap, you can mod a short version easily, and having a screw with a head is better than a tiny setscrew... Make the screw as large as reasonably possible for a wider clamp area and less chance of stripping.
Clonebug
Post by Clonebug » Wed Sep 07, 2016 9:13 pm
Model airplanes use a connector that goes from cable to threads. You can solder those ends on the cable. They come in different thread sizes and pitches.
http://www3.towerhobbies.com/cgi-bin/wt ... LXD924&P=7
Here is one that is 4-40 thread. They also have ball connectors.
I used one of these before and they worked good.
