36-2 trigger wheel settings
Moderator: Tom Notch
ruff
Post by ruff » Sun Apr 02, 2017 3:08 am
hello guys,
changing from 009 to wasted spark..
I will use a 36-2 trigger wheel ( 2 missing teeth are next to each other )
Is the tooth 1 angle still 80 degrees?
I am a bit confused with this weird trigger wheel :)
( I used a 36-1 before and used 80 degrees there )
thanks, Peter
Re: 36-2 trigger wheel settings
Post by Piledriver » Sun Apr 02, 2017 1:45 pm
Works the same, still need to verify with timing light.
I'm running a 36-2 ATM in a 009, was supposed to be a 36-1 but had one of the settings wrong on my welder... :roll:
Its a steel spur gear from a gas rc truck.
A 72 tooth will even fit...
ruff
Post by ruff » Sun Apr 02, 2017 3:32 pm
thanks a lot!
your setup is very nice!
gives my ideas!!
Peter
