Bosch 044 to big?
Moderator: Tom Notch
Wentzel
Bosch 044 to big?
Post by Wentzel » Sun Nov 19, 2017 12:53 pm
Hi guys I need some advice.
I am currently running a Bosch fuel pump (cant remember the model but probably off a vanagon or golf). It has been running great for many years but started whining recently.
My question is can I replace it with a Bosch 044? I am using 47 lb/hr injectors and fuel pressure of around 43psi. The pump will need to be replaced anyway with future engine upgrades that I am busy with, will it circulate too much fuel in my current setup or should it be ok?
I don't want to replace the pump now and later again with an 044.
Re: Bosch 044 to big?
Post by Chip Birks » Sun Nov 19, 2017 6:07 pm
Just use the 044
petew
Post by petew » Sun Nov 19, 2017 10:55 pm
If you can easily get an 044 then for sure... On the other hand, there is also the 070. I've used this on 2 different projects now. Safe for up to 300hp on turbo applications and came as a factory pump on a bunch of cars including mercs and local holdens (GMs). More than enough for anything I'll ever do on my car.
https://www.amazon.com/s/ref=nb_sb_noss ... +fuel+pump
I buy them because people want to put a premium on 044s over here. The 070 can be bought at ANY parts store for around $100.
Wentzel
Post by Wentzel » Mon Nov 20, 2017 8:06 am
Thanks guys I just needed to check before I buy. Will see what is available locally.
Wally
Post by Wally » Wed Nov 29, 2017 1:36 pm
Just use the 044
I agree. The originals are made in Chech republic iirc and are not that (more) expensive.
Wentzel
Post by Wentzel » Thu Nov 30, 2017 2:09 am
Thanks Wally
Got hold of a 044 Pump for a decent price. Waiting for delivery and hoping to install it over the weekend.
