fuel cell/tank
Moderator: Tom Notch
elrockk
fuel cell/tank
Post by elrockk » Sat Apr 07, 2018 7:33 pm
hello all i Have a question what kind of fuel cells/tanks are you using for E85 turbo setups.most aluminium say not for E85 and ive read no plastic for E85 so im looking for what you guys/girls are useing thanks for any input
risk
Re: fuel cell/tank
Post by risk » Tue Apr 10, 2018 9:20 am
I use the stock tank with aeromotive stealth e85 pump installed from the top.
Re: fuel cell/tank
Post by Chip Birks » Tue Apr 10, 2018 9:50 am
Stock steel tank here, treated with POR fuel tank sealer. In-tank pump with mine as well!
risk
Re: fuel cell/tank
Post by risk » Tue Apr 10, 2018 10:30 am
I wouldn't see a problem with plastic. What is this going in.. a stock beetle or race car of some sort?
elrockk
Re: fuel cell/tank
Post by elrockk » Tue Apr 10, 2018 7:52 pm
for now its a stock 1600 but im gonna make a 1915 . i got flex fuel injectors a small garret turbo and just thinking a fuel cell be the easyist way to go with AN fittings . so you have no issues with the stock tank and E85? because then i would use the stock tank to feed the fuel cell and get my AN Inlets and outlets.is there a possibility the foam in these cells is not good with E85? thanks for the replies
Re: fuel cell/tank
Post by Chip Birks » Tue Apr 10, 2018 8:10 pm
Why 2 tanks? Don't overcomplicate it. Weld some AN fitting on your existing tank and call it good. You can tap the outlet for 1/4 npt and then get an npt to AN adaptor and your golden. Weld a second bung on the bottom if you want. Or do an intank setup and run one or both fuel fitting right out of the top.
risk
Re: fuel cell/tank
Post by risk » Wed Apr 11, 2018 9:10 am
I have been running E85 for five years now and have not had any problems with the stock tank.
I started by welding an AN outlet on the tank, and using the stock outlet as my return with an external pump. I ran a big aeromotive pump and it was noisy. Now I have in-tank and love it. Very quiet and both the wiring and supply and return lines are on top.
If you want quick and easy, tap the tank outlet as chip said or CB sells a fuel tee that threads on the stock tank outlet.
https://www.cbperformance.com/product-p/6483.htm
elrockk
Re: fuel cell/tank
Post by elrockk » Wed Apr 11, 2018 7:23 pm
do you have any pics of your tanks?
Clonebug
Re: fuel cell/tank
Post by Clonebug » Wed Apr 11, 2018 8:15 pm
I tapped my tank for 1/4 NPT and put a brass tee on it with AN fittings to match my 1/4 inch return hose and AN-8 Pump feed hose.
These are brass nipples but I have upgraded them to push-loc swivel nipples on the hoses and AN-4 and AN-8 male fittings on the brass tee.
elrockk
Re: fuel cell/tank
Post by elrockk » Thu Apr 12, 2018 7:39 pm
yes that would be much simpler thanks
andy198712
Re: fuel cell/tank
Post by andy198712 » Fri Apr 13, 2018 1:46 pm
CB sell a billet version of that that just screws on to the outlet, was good for me as in UK NPT taps are hard to come by and ALOT more then in the US, but worth looking into....
risk
Re: fuel cell/tank
Post by risk » Fri Apr 13, 2018 2:32 pm
Here is how I did my in-tank setup. The car used to have a gas heater so I just ran my fuel lines through the old holes for it.
This pic shows the foam and rubber base that goes down in the tank.
And the 100 micron filter below the tank:
elrockk
Re: fuel cell/tank
Post by elrockk » Sat Apr 14, 2018 7:35 pm
thats a nice setup but its out of my price range right now. do you know of any/or how to get wires sealed leak proof into the tank for a in tank fuel pump
Re: fuel cell/tank
Post by Chip Birks » Sat Apr 14, 2018 9:14 pm
I did mine pretty cheap, I'll see if i can get some photos later today.
raygreenwood
Re: fuel cell/tank
Post by raygreenwood » Sat Apr 21, 2018 12:39 pm
Modern factory fuel tanks are typically HDPE (high density polyethylene). That material has no problem with any fuel. It has very minor surface attack/drying from 95% ethanol....and would likely take several decades for cracking to start. UHMW (ultra high molecular weight polyethylene) is even stronger but more expensive. Ethanol cant touch it.
HDPE is just fine for E-85. Ray
