Slick motorcycle ITB mounts for IDF manifolds
Moderator: Tom Notch
djb
Re: Slick motorcycle ITB mounts for IDF manifolds
Post by djb » Sun Jun 10, 2018 4:23 pm
Can anyone confirm the year range for the Honda VFR800 TB's? The ones I am finding on Ebay do not look like the images posted in this thread.
Also would if someone could confirm the part number of the Mikuni adapters?
Thanks!
David
TZepeSH
Post by TZepeSH » Mon Jun 11, 2018 1:34 am
You are looking for 99-01 throttle bodies. About the rubber boots, I can not confirm. I milled the IDF manifolds such that the throttle bodies go in by 10mm, and used an O-ring to seal. And some little steel plates to fix the throttle bodies down. Sorry no pictures now.
TZepeSH
Post by TZepeSH » Wed Jun 13, 2018 3:15 am
Here is my install. What kind of filters do you plan to use? The IDF K&N type will hit the fuel rail and the air holes are mis-aligned by maybe 10mm. I think that a 20mm spacer would solve the problem I also want to use the original velocity stacks.
viewtopic.php?f=1&t=138151&sid=cfe8c2b3 ... &start=180
