Reading info
Reading info
Can anyone suggest any good readying to help with trying to figure out this tuner studio? All this new software is confusing.
- Chip Birks
Re: Reading info
New tuner studio is better than old tuner studio. Almost every feature has a blue question mark next to it. You can click on it and it will tell you about the feature.
Re: Reading info
Okay, I'll have to check that out the next time I am out in the garage. The way the weather has been lately here in Michigan, that could be next week.
- TouringBubble
Re: Reading info
Chip is right. The latest firmware is great. Nearly everything is notated.
Follow my SCCA Rallycross build on Facebook.
Dirty '73 Beetle. 2109cc with way too much intake.
Power numbers to come.
Sponsors: Satellite Racing - Defined Performance
Re: Reading info
may I ask what version of tuner studio your running? I believe mine is the latest version. 2.5.14 and MS extra 3.2.4. I see that ms has a new extra 3.3.1. Is it worth loading?
Re: Reading info
It is always a good idea to run the current release firmware.
The features added and bugs fixed make it well worth it.
(also, if you have any problems upgrade to current is the first order of business, as the devs are not going to try and debug old code)
I have personally been running the alphas etc essentially since day 1, several years now.
- vwi_dduvall
Re: Reading info
Sorry for a very noob question but where can you see what firmware your running? I update several months ago but seem to be running into postings and questions of if I have update and now I am thinking i need to verify I am current.
Thanks,
Daniel Du Vall
Thanks,
Daniel Du Vall
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
- vwi_dduvall
Re: Reading info
Was a noob question figured it out.vwi_dduvall wrote:Sorry for a very noob question but where can you see what firmware your running? I update several months ago but seem to be running into postings and questions of if I have update and now I am thinking i need to verify I am current.
Thanks,
Daniel Du Vall
Daniel Du Vall
Re: Reading info
Just for anyone else who still wonders, the TS version and firmware version (when connected) will be shown in the programs window title at the top,,,, at least in Linux or Windows. (probably MacOSX.x too)
- Volky
Re: Reading info
Good day,
I was over at MSextra and came across this:
http://www.msextra.com/forums/viewtopic ... 01&t=53211
I implemented this to my tunerstudio and it works flawlessly. The TS software now was a help tab in each topic you inquire.
I find it handy, instead of looking for info in my laptop, Internet, etc, you have a quick reference instantly.
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me... t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
Re: Reading info
Very slick, should be available for MS3 RSN as well.
