Injector Service Company?
- Max Welton
Can anyone recommend a company for servicing and flow-testing injectors?
Max
Max
Re: Injector Service Company?
I can have it done locally even in little ol Boise. Try contacting auto machine shops or performance shops.
For under 100 bucks I can have a set cleaned, o-ringed, and flow tested here.
On the type with hoses (van, bus, old bug) they even have new crimped on hoses for that price.
Steve
My Baja Build
My Baja Build
- Max Welton
Thanks Steve.
Max
Max
- Fiatdude
RC Engineering
- Max Welton
Can't quite remember, but I think that's where I got my fuel-rail stock.
Max
Max
- veloracer
- Hoodrich
I used Witch Hunter. Fast turnaround - great results.
- Max Welton
Just got my injectors back from Pro Flow Technologies.
Before and After:
And the flow test results:
Cost: $89.
I think I will send them the Ford injectors I am using in my MS2 type-3 engine.
Max
Before and After:
Cost: $89.
Max
- Max Welton
OK, I just got the 97 Ford Escort injectors back.
According to the sheet, they flow 33 ml in 30 seconds at 40 psi.
1 ml = 1 cc
So 66 cc per minute
According to http://www.witchhunter.com/injectorcalc1.php that is 6.3 lbs/hr.
Does that sound right?
Max
1 ml = 1 cc
So 66 cc per minute
Max
- trbugman
It sounds like your injectors are 33lbs/hr. If they were 6.3lbs/hr they came from an awfully small engine with very little HP.
2333(103x70) Type 4 DTM MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next.
- woodsbuggy1
I recently used Linders Injectors service in Speedway IN. They took 2 weeks to service my TBI injectors(tow vehicle) when I was quoted 3 days and charged more than quoted price. They are only 2 hours away from me. Next time I will use WitchHunter.
Good Luck
Kenric
Good Luck
Kenric
There's so many different types of measuring, lbs/hr, cc per what ever, mls?
I get so confused lol
- Max Welton
I am assuming 33 ml, but the units aren't indicated on this one like they were for the Honda injectors. I've just sent a request for help to ProFlow. Given the holiday weekend, I don't expect an answer till next week.
Max
Max
66ml is 66cc, so makes them 66cc injectors (think gsxr ones are 225/240cc ish for lowers and something like 400cc for uppers @3bar or 43psi)
maybe i've got my units crossed?
