I have spent many hours reading the forced induction forum, Turbo threads, FI threads, My brain is on overload and going 100 directions for this.... I have a 74 super beetle with stock engine. My long term plan is to build a 1776 FI Turbo and i'd like to transfer all of this to it with whatever improvements needed for the higher performance / more demands..... Also, thinking E85 at that time so i'll need to prepare for that too.
At this time i am tired of the stock setup with 34pict-3.
I have a MS V2.2 board that i've got 50% completed and also have the relay board (this was all free so i'd prefer to work with if i can)
I'd like to use this setup but read that i may have limitations. Maybe for now it'll work but as i get into performance maybe no? (v3.0 at that time?)
Ignition: direct fire an EDIS style coilpack or coil near or on plug?
Intake: I'd like to plan for the future, I had considered the Mexi-FI but read about the lower airflow. So i am thinking CB FI intakes (not the High flow version) I believe i'd still like to run a single TB in the middle.
Sensors: TPS on TB, Cyl head temp tapped into the head? IAT below the TB? Wideband O2 in the muffler/header?
Please help me make some sense of this. I plan to install suspension soon, and would like to roll into the FI project immediately after.
I know its 100 things, but i'm a little overwhelmed with the amount of info out there and just need to narrow it down.
Thanks ahead for any and all help guys!
Getting ready to dive into Megaquirt... stock 1600 at first.
Re: Getting ready to dive into Megaquirt... stock 1600 at fi
Looks like a great project!
If you have Megasquirt info overload, make sure to ONLY study the MS-extra manuals--- the far more advanced -extra firmware uses the hardware a bit differently, and reading the B&G Megamanual as well is certain to cause headaches.
E85 is a bit of cake if you plan the fuel system right. New GM flex fuel sensors can be had for ~$35 these days.
(in the midst of doing this myself, the engine likes it... a lot. fuel costs are a wash.)
Gates multi-fuel hose is a good thing.
You can read through my build to see an install of a Ver 2.2 Ms-1 extra with EDIS.
As far as I know the Ver. 2.2 board can't do direct fire without a bunch of work. It is set up to do EDIS with the Module.
I ran EDIS for three years without any issues... it is a robust setup and reliable. You will have a few more wires to deal with and also the module to place but it's not too difficult.
Here is how I placed the Module in the coil mount area.
I mounted the coil in front of the shroud to hide it for a cleaner look.
I used the Stock German Plenum and Throttle body for a year with the MS-1 but built my own intake this past winter to get rid of the clutter and get a smoother throttle pedal.
I'm using Volvo 940 turbo 32# fuel injectors, fuel pump and a Golf filter and currently running 17 lbs boost on my 1679.
Here is my homemade intake using the stock German TB.
Water injection, vacuum/boost reference and IAT sensor added.
CB FI intakes are great for ease of installing FI.
Thanks clonebug. ... I'm on page 42 of your thread, been reading it for a couple weeks. Big inspiration!
EDIS vs direct coil control is pretty much a wash if you are using waste spark, IIRC you lose spark cut with EDIS but may gain multi-spark at low RPM depending on the specific EDIS modules capabilities.
(I think they both use the same number of IOs, but I have not looked lately)
OTOH direct coil control appears easier to troubleshoot as you can fire a specific coil at will in test mode.
Also, any EDIS module or component you can buy short of new is ~10-20 years old.
