36-1 and crank sensor
Re: 36-1 and crank sensor
Okay, I am now powering the sensor with 12v and it seems to like it, can I do the same with the injectors?
clintonddk wrote:Okay, I am now powering the sensor with 12v and it seems to like it, can I do the same with the injectors?
The injectors? wont run any other way than off 12v, i think you meant something else.
The std analog sensors need vref.
If you have an ethanol sensor, it runs on 12v.
