Spark Plug Wires for VW Four Tower Wasted Spark Coil
Posted: Tue Oct 04, 2016 1:48 pm
by bladerunner80
Anyone have any suggestion on spark plug wires when using a VW wasted spark coil? I can't use the stock wires (they look too short) plus they have the funky spark plug connectors. Can I buy a set of universal plug wires? If so, what type of connector does the coil pack use?
Re: Spark Plug Wires for VW Four Tower Wasted Spark Coil
Posted: Wed Oct 05, 2016 6:49 am
by kangaboy
I don't know what the coil pack plug ends look like, but I used a set of vanagon wires for my LS2 Coil set up. They are super long, so I was able to take off the ends, cut them to length, and reattach the ends. Works like a champ. If worse comes to worse, you can get a set of MSD wires and plug ends, and make your own. I think I saw that Mario was making/selling wire sets on his website too (thedubshop.net)
Posted: Wed Oct 05, 2016 12:48 pm
by bladerunner80
Thanks Kangaboy. I think the VW coil pack uses the same style connectors as the LS coil packs. I ordered a set of universal taylor wires and a separate LS coil pack terminal kit. Hopefully that will do the trick. I compared a bunch of pictures of the stock VW plug wires that work with the coil pack and the LS coil pack wires and ends look pretty similar.
Posted: Fri Oct 07, 2016 4:02 pm
by Big Ratfink
The last set of MSD wires I bought came with a crimp tool so I could cut to length and crimp whichever ends I needed.
Posted: Thu Oct 13, 2016 3:05 pm
by Thorkhild
I started with the taylor made 8mm from aircooled.net and changed my dizzy end with these .
https://www.summitracing.com/parts/msd- ... d-ignition
to use with my IGN-4 from diyautotune
