1600i with MS2 tables
Posted: Fri Dec 02, 2016 2:37 am
I have spent the past 6 months tuning and tweaking a Mexican Beetle 1600i running MS2 courtesy of Mario at The Dubshop.
The engine is a low mileage original factory engine with all stock FI fitted + a Wideband sensor and a 35mm merged exhaust.
I thought it would be helpful to post my tables now the car is running pretty sweet - feel free to do the same if you have a similar set up as I struggled to find any tables for the Mexibugs.
I have also attached a MAP in case anyone needs a base: https://www.dropbox.com/s/2067461rimrpl ... i.msq?dl=0
