Stock Mexican temp sensor calibration setitngs
Moderator: Tom Notch
paullanzarotti
Post by paullanzarotti » Wed Jun 07, 2017 1:28 pm
Does anyone have the settings for the stock Mexican cylinder and air temp sensors?
gtmdriver
Re: Stock Mexican temp sensor calibration setitngs
Post by gtmdriver » Thu Jun 08, 2017 4:28 am
This is my VW OEM sensor
and this is the calibration curve for it.
Is this any use?
paullanzarotti
Post by paullanzarotti » Thu Jun 08, 2017 7:42 am
Hi GTM
Thanks for this - where is that sensor from? I'm using a stock Mexican ACD engine with stock Siemens temp sensor 113 906 161 which I think has a different profile.
What have you set the bias resistor factor at?
Also - do you have settings for the stock Mexican Air Temprature sensor?
gtmdriver
Post by gtmdriver » Thu Jun 08, 2017 2:23 pm
VW Heritage list it for
Beetle 1975-1979 | T2 Bay 1974-1978 | Type 3 1970-1973 | Type 25 1980-1983
It screws into a tapped boss on the cylinder head.
The bias resistor is 2490 ohm.
I didn't build my MS 2 v3.
paullanzarotti
Post by paullanzarotti » Thu Jun 08, 2017 4:32 pm
Ah ok - interesting. I haven't seen a sender like that before.
Is the bias resistor value the same for all MS boards? 2490 ohms??
paullanzarotti
gtmdriver
Post by gtmdriver » Fri Jun 09, 2017 5:08 pm
I honestly don't know.
