Gathering Parts for Microsquirt need advice on VR sensor
Moderator: Tom Notch
Schweg
Post by Schweg » Tue Feb 06, 2018 5:02 pm
Hello,
I'm new to the forums, I have been reading a lot. I have a 1600DP Baja Beetle I'm looking to put a turbo and microsquirt EFI. Initially I would like to use the microsquirt for ignition only. I have a small budget issue, as in it will not support a bad a$$ thedushop.com system.
Is there any recommendation on a type or Part number VR sensor to use? I plan on using a 32-1 wheel: GM TPS, IAT, ECT and Map sensor.
Thanks in advance.
Schweg
Re: Gathering Parts for Microsquirt need advice on VR sensor
Post by Chip Birks » Tue Feb 06, 2018 10:46 pm
Old school Ford escort trigger wheels can be found at local pick and pull places. I used Late 90s Taurus triggers on mine. Escort sensors work good. Early 90s on the escorts.
Schweg
Post by Schweg » Wed Feb 07, 2018 6:45 am
Chip thanks for the reply, and the information I’ll check it out.
Do you know if it is a VR or Hall sensor?
Schweg
Post by Chip Birks » Wed Feb 07, 2018 8:27 am
Vr
Schweg
Post by Schweg » Wed Feb 07, 2018 6:22 pm
Thanks again
gtmdriver
Post by gtmdriver » Thu Feb 15, 2018 12:04 pm
I'm using a Ford sensor which I got new from Triggerwheels.
I also got the 36-1 toothed wheel, Ford coil pack, connectors and various other bits from them.
Not the cheapest but very helpful and they have most if not all of the bits you'll need.
Schweg
Post by Schweg » Fri Feb 16, 2018 3:35 pm
Thanks , I’ll take a look at there stuff. Also is that a ford wheel or one from triggerwheels.com?
Also I noticed you aren't running a distributor are you running a second sensor for cam position?
Sorry for the questions just a lot of info out there.
panel
Post by panel » Thu Feb 22, 2018 12:20 am
You mean a 36-1 ?
Subaru JDM EJ20 Turbo bus
Schweg
Post by Schweg » Thu Feb 22, 2018 6:31 am
No?
All the wheels I have seen are 36 and 1.
Post by Chip Birks » Thu Feb 22, 2018 9:22 am
No?
You stated 32-1 on your first post. He is just making sure it was a typo rather than you building an oddball.
Schweg
Post by Schweg » Thu Feb 22, 2018 10:46 am
It was an error.
Thanks Chip.
I was out of it this morning when I read it.
gtmdriver
Post by gtmdriver » Thu Mar 01, 2018 5:11 am
The pulley is an OEM VW component and the 36-1 wheel is from Trigger Wheels. It was welded to the pulley then trued on a lathe. Runout has to be minimised to get a consistent VR signal.
I am using the MS 2 v3 to drive the ignition so the distributor is not needed.
You don't need a cam position sensor unless you want to run timed or sequential injection.
Schweg
Post by Schweg » Thu Mar 01, 2018 12:29 pm
Double
Schweg
Post by Schweg » Thu Mar 01, 2018 12:30 pm
GTM,
Thanks for the information.
Another question. Did you run your return fuel line through the tunnel? Or external to the body?
Schweg
risk
Post by risk » Thu Mar 01, 2018 3:59 pm
It seems like everyone here runs their fuel lines a little different.. some inside the tunnel, others outside. They all work.
Some use the stock fuel line as a return, and run a separate sometimes larger (big hp turbo motors) main line.
I abandoned the stock line and ran two 3/8" stainless steel lines inside the tunnel.
If you plan on off-roading your Baja, inside the tunnel is the best place. You will have to secure it in a few places so it doesn't bounce around in there and rub a hole in itself. This is the best, but also the most difficult place to run the line.
