Type 4 - Semi-Sequential Settings
Moderator: Tom Notch
luftvagon
Post by luftvagon » Sat May 12, 2018 3:19 pm
I'm looking to see if anyone implemented Semi-Sequential Fuel in their Type 4 2.0L.
I enabled it as a short test. Previously run untimed injection with 2 squirts simultaneously.
Now:
[*]4 Squirts Per Cycle / Alternating (Injector Bank #1 = 1,3 | Injector Bank #2 = 2,4/Matches Wasted Spark Configuration)
[*]Squirt at 90 degree, at the end of pulse.
I noticed a slightly better response, and when at operating temperature, I feel like I gained 300 more RPM at idle? Maybe a coincidence.
Has anyone experimented with other degrees? Suggestions?
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
