Accel pump enrichment Issue MS3X
vwi_dduvall
Post by vwi_dduvall »
Issue: Lean spike after rich spike (or dip on graff for enrichment) this issue is better during the morning hours when the temps at cooler roughly in the 60-70 F.
As the temp goes up above 70 say 80 it gradually gets worse. I have tried all TPS and all MAP and different mixes of both with no success.
I am probably missing something somewhere if anyone has any ideas or input I am all ears.
This setup is on a 1600 type3 with MS3X and 24 tooth distributor sync.
Wideband O2 full sequential
I can provide a log and tune as needed.
Thanks,
Daniel Du Vall
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
vwi_dduvall
Re: Accel pump enrichment Issue MS3X
Here is a link to the last set of logs and the project backup:
http://volkswageninsanity.us/Postings/F ... 8/01SEP18/
Thanks,
Daniel Du Vall
Daniel Du Vall
vwi_dduvall
Bump!
Anyone?
Please
Daniel Du Vall
Daniel Du Vall
Post by Chip Birks »
Haven't looked at logs yet, on my phone right this second. Do you have it set to the accel pump carb like setting? I haven't really spent much time messing with my accel settings, other than to set them to that.
vwi_dduvall
yes carb like setting/
Daniel Du Vall
