Porsche door pull idea
Jadewombat
Contact:
Post by Jadewombat » Sun Oct 01, 2017 2:17 pm
I borrowed the old idea which Porsche has and still uses on their cars for years. I used some red strap from a tie-down strap as the webbing material, a strip of thin aluminum for the bracket, and a couple of very small self-tapping screws. I sheared the aluminum to the correct size and folded it over on the strap. The two screws and the tension of the bracket sandwiched on it should hold it in place (as long as my daughter doesn't try to hang on the strap, :) ).
Tony Z
Re: Porsche door pull idea
Post by Tony Z » Sat Mar 31, 2018 12:05 pm
Simple and neat... I might just use your idea sometime
ps2375
Post by ps2375 » Mon Apr 02, 2018 4:00 pm
I am having to replace inner door panels and have toyed with the idea of door pull strap instead of the armrest. But, I do like being able to rest my arm on the armrest (hence the name I suppose).
Jadewombat
Contact:
Post by Jadewombat » Mon Apr 09, 2018 8:28 pm
If you can get used to putting your left elbow up on the lower edge of the window??
