My new brake upgrade!!
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
capsoval
Post by capsoval » Fri Oct 01, 2010 11:48 pm
Old setup was CB's standard disk brake kit that I had crossed drilled and coated. Stopped great with my 18" rims, but my speed and power needs have gotten much greater in resent years and I was wanting to upgrade my brakes with something cool yet different.
Old setup....
Machined hub
Old rotor on top of new rotor, std 2005 911 rotor
New caliper, C6 Z06 6-piston
Wheel mounted back up
Its not completed yet, just wanting to show what Ive been doing progress wise. Hope it helps out others as well.
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
Re: My new brake upgrade!!
Post by Piledriver » Sat Oct 02, 2010 1:17 am
Very Slick, what did you do for the caliper mount?
capsoval
Post by capsoval » Sat Oct 02, 2010 1:51 am
What im doing is making a plate the bolt pattern of the spindle and a plate the pattern of the caliper. Then fix the caliper in the proper location and tack a plate between them. Then ill clean it all up and fully weld it off the car. I'll post pics of it, very simple but the pics may help others.
Post by Piledriver » Sat Oct 02, 2010 2:55 am
capsoval wrote:What im doing is making a plate the bolt pattern of the spindle and a plate the pattern of the caliper. Then fix the caliper in the proper location and tack a plate between them. Then ill clean it all up and fully weld it off the car. I'll post pics of it, very simple but the pics may help others.
Yes, pics very helpful.
I have some 996 rears and $75 LS430 front calipers I want to try (and 996 discs) to mount on the Pile when I get back to it.
(I actually don't like the front struts I picked up, rust pitting to the point of worrying about structural integrity-be careful of parts purchases from PA)
The `vette parts are probably easier to mount.
volkdent
Post by volkdent » Wed Oct 20, 2010 10:42 pm
I'm guess you just put the calipers on top to demo, but make sure you've got a top and a bottom when you actually mount them or bleeding may be a pain in the a$$!
Jason
capsoval
Post by capsoval » Tue Feb 15, 2011 11:42 pm
Update: all finished
Image[quote][/quote]
Steve Arndt
Post by Steve Arndt » Wed Feb 16, 2011 11:28 am
Did you make caliper adapter plates?
pics?
DerrickfromNC
Post by DerrickfromNC » Wed Feb 16, 2011 2:24 pm
What kind of mc are you using? If stock beetle I would interested in knowing what kind of pedal travel and feel. I've got at set of front Porsche 996 rotors & calipers I'm going to install.
capsoval
Post by capsoval » Wed Feb 16, 2011 4:57 pm
I believe it a 914-6 mc, although I am not sure what 914 it came from. 55superbeetle got it for me and it worked perfect for my CB 4 wheel disks. I'll have to ask him to find out.
DerrickfromNC
Post by DerrickfromNC » Wed Feb 16, 2011 5:32 pm
capsoval wrote:I believe it a 914-6 mc, although I am not sure what 914 it came from. 55superbeetle got it for me and it worked perfect for my CB 4 wheel disks. I'll have to ask him to find out.
Great, was it bolt on? Also if you could find out if the 914-6 mc is the same as some early 911 mc that I have heard others use.
capsoval
Post by capsoval » Fri Feb 18, 2011 10:56 am
I spoke with 55superbeetle,
914 mc is 17mm bore.
914-6 mc is a 19mm bore.
Early 911 mc are the same as 914-6 mc.
It turns out the one I'm using is a 914-6 mc.
bender
Post by bender » Tue Mar 08, 2011 7:28 pm
ATE..MB..23MM Bolt's up...No mods...Great for BIG brake's.... :mrgreen:
Yannick33
Post by Yannick33 » Wed Mar 09, 2011 5:02 am
Nice parts !!! The brake fluid reservoir come from which car please ? Does it fit directly on the MC ?
Thx :wink:
Post by Piledriver » Wed Mar 09, 2011 8:19 am
Can't quite make out the part# on that, but should work great!
bender
Post by bender » Wed Mar 09, 2011 12:30 pm
The reservoir slips on and fits, Clears the wall...Trick to fill ..
Reservoir is a VW/AUDI Part # 443 611 307...
Im trying to find a # for the MC.....
