911 alternator alternate ?
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
panel
Post by panel » Sun Feb 13, 2011 2:36 pm
I wondered if you guys had seen or done a conversion using another style of alternator in place of the Porsche alternator but still using the fan and shroud etc? I have a Motorola one now with an external regulator .
Subaru JDM EJ20 Turbo bus
Daniel G
Re: 911 alternator alternate ?
Post by Daniel G » Mon Feb 14, 2011 7:07 am
I have also wondered about this myself. I would think somebody out there has done at least one at some point. Maybe a high output GM 1-wire alternator in place of the Porsche one? Porsche hi amp alternators aren't too cheap :lol:
Steve Arndt
Post by Steve Arndt » Mon Feb 14, 2011 11:55 am
I have a late 60s 911 motorola alt and fan I could sell.
My PTP/Knuf 911 setup uses a Golf alternator.
DWP
Post by DWP » Mon Feb 14, 2011 12:33 pm
About the only info I have found
http://www.ratwell.com/technical/Alternator.html
DWP
As i tell my son, waste money on cars not Girls.
You can always sell the Car.
DWP
Post by DWP » Mon Feb 14, 2011 3:02 pm
Just came across this on the germanlook site
Anybody from germany to chime in
http://www.germanlook.net/forums/showthread.php?t=11164
DWP
andy198712
Post by andy198712 » Fri Aug 03, 2012 5:13 am
so you buy that plate, then buy a golf alternator, and fit it to your fan and ring and shroud?
Post by Piledriver » Fri Aug 03, 2012 5:35 am
What plate?>dead link/closed auction.
Post pictures, preferably with DIMENSIONS.
Bosch and Motorola are not the only manufacturers of alternators, there are literally thousands on choices.
(just as an example, no idea if it will work in this app)
The GM CS130D I picked up new from my local FLAPS was $129, and carries a lifetime warranty.
(as long as you own the vehicle, in my case, usually a bad move on their part)
That model/type is still being used in current model year AFAIK, and is as common as salt, and comes in many mounting configurations.
Has the same shaft size etc as the late Vanagon alt I was planning on using,(I used the larger Vbelt Vanagon pulley, as the included serp belt wasn't happening) has dual internal fans, double row+ large sealed bearings on either end, and will put out >rated current ~13.4v for as long as I had patience to test. It's also considerably smaller and ideally suited to a vehicle running EFI, due to the PWM internal voltage regulator and diode packs designed for that purpose.
Something smaller can be made bigger/adapted easier than the reverse, at least in this case.
andy198712
Post by andy198712 » Sat Aug 04, 2012 7:37 am
true, i dont understand why it hasnt been done.
i just want a cheaper way to go porsche cooling (purely for looks)
Post by Piledriver » Sat Aug 04, 2012 8:37 am
andy198712 wrote:true, i dont understand why it hasnt been done.
If you are looking for fuel economy or cooling, many of the 911 fan setups lose vs. stock T1, even non-doghouse..
(for cooling uniformity) you also want to keep a working thermostat.
andy198712
Post by andy198712 » Sun Aug 05, 2012 12:36 pm
i know, its purely a lust thing :oops:
that ir a DTM but trying to get one in the UK is a bit of a joke, going buy ebay, the kit is $500 and postage is $700....
andy198712
Post by andy198712 » Sun Aug 05, 2012 2:40 pm
Gene running a porka fan!!!
Steve Arndt
Post by Steve Arndt » Sun Aug 05, 2012 3:13 pm
On a 911 engine...
andy198712
Post by andy198712 » Sun Aug 05, 2012 4:29 pm
Steve Arndt wrote:On a 911 engine...
:oops: :oops:
Post by Piledriver » Sun Aug 05, 2012 6:34 pm
:oops: :oops:
With no fan belt?
andy198712
Post by andy198712 » Wed Aug 08, 2012 8:25 am
http://www.autopartswarehouse.com/mmp/p ... parts.html
those seem cheap, are they the right ones? (obiously some are not but which ones are?)
i was looking at this to go with it http://www.volkszone.co.uk/VZi/showthread.php?t=785805
