suspension advicce
old gh bug
suspension advicce
Post by old gh bug »
I am hoping to get some advice on what suspension set up to use on my 1303 convertible
It is a late model with rack and pinion and 2 bolt front end ,i am wanting to lower it a bit and also change to Porsche wheels
I have some other "lowered front struts and springs with 944 stubs etc please see pic
I have cleaned and coated these up and they are just about ready to go But after reading lots of threads i am a bit unsure what i can use to get right set up in terms of springs ander camber???
I think the white springs are going to be to low so i have the option of the red ones that suppose to be 2" lower
What i would like to know is can i use these as they are of 3 bolt struts and can i also use the strut tops on the 2 bolt ones
Also i understand that using the the 944 stubs causes positive camber , is there any way i can overcome this with the items i have ?
Thanks garry
